06-01-2009, 04:58 PM | #1 |
Clutch or trans making this noise???
Ok heres my saga. The truck was making a bad noise from what I thought was the release bearing. Replaced it last friday. The bearing(release) fell apart when the trans was removed. I inspected the clutch as much as possible but was sure this was the issue at the time so we put the trans back in and tested. I adjusted the clutch and to my dismay its doing the same stinking noise. When the clutch peddle is in with the truck not moving no noise. When moving you get a sound kinda like a washing machine washing ( if youre washing rocks) and a clicking sound. And if you depress the clutch but down shift, the noise speeds up. I never let the clutch out just down shifting and coasting. Something in the trans (M-21) bearing or worse in there,? Clutch maybe.? Ideas,? suggestions. ?thanks, Mike
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
06-02-2009, 05:01 PM | #2 |
Re: Clutch or trans making this noise???
Well???
06-02-2009, 05:13 PM | #3 |
Did you replace the pilot bushing while you were in there? Is you linkage adjusted properly? Sounds like the clutch isnt all the way disengaged.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
06-03-2009, 05:02 PM | #4 |
Yes to all
06-03-2009, 06:30 PM | #5 |
Cool Truck
I would guess it is the tranny. My four speed took a dump on me in January, but starting in late December, it would make a kind of scratching, weird sounding noise in 2nd gear. I thought it was the clutch and I kept driving it, but it eventually got worse and the only gear it would make the noise in was 4th.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
06-04-2009, 04:02 PM | #6 |
thanks, pulling it again sat...
06-04-2009, 04:55 PM | #7 |
Cool Truck
I am no mechanic, so if my guess is wrong, don't blame me.
