06-01-2009, 08:27 PM | #1 |
Grandpa in the rustmobile...
fr tire has a bad camber after i switched to disc brakes in front..
okay, when i swapped to discs and diff. front wheels i noticed a slight camber in my front wheel.........my right front wheel to be exact. well i took it to get aligned today, and they couldnt align it because it had too much of a camber, lucklily they didnt charge me anything, i asked the man who worked on it he said i couldnt be the way i put the spring in..im thinkin
#1 spring went in crooked or upside down #2wheel is bent/warped(truck wheel came off of had slight fender bender) #3 spindle is warped bent gonna fool with it tomorow... watchall think
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-01-2009, 09:55 PM | #2 |
Hellasick
Re: fr tire has a bad camber after i switched to disc brakes in front..
Wish I had a good answer for you, but know what you mean. When i did mine, my camber was way off. When I had it alligned, they removes all the shims from the pass. side, about 5 of them, and the dr. side only has one left of about 5. I don't know why is was sooooo off. Used same springs, maybe was the way the balljoints fit-more distance between lower control arm and the spindle or it the '85 spindles are actually "taller" but have not seen anyone claim that around here.
Good luck is all i can really offer.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
06-01-2009, 10:55 PM | #3 |
you never got it aligned and still running a off camber tire huh...bummer id liek to get it alinged..anybody else
06-02-2009, 12:54 AM | #4 |
Just Not Low Enough!
did you replace the balljoints hen you did the swap?
other than that it may be the spring not aligned, or upside down in the pocket. if that doesnt fix it it sounds like something may be bent....just a guess.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
06-05-2009, 05:08 PM | #5 | |
Hellasick
No no...I got it aligned, thus the removal of most of the shims. Aligned real well, until I replace the trailing arm bushings that is...
06-04-2009, 10:07 AM | #6 |
Same problem here. Spring upside down, hadn't thought of that.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
06-04-2009, 11:01 AM | #7 |
Spring may not be seated but can you put it upside down??
Warped wheel would be easy to detect by jacking up and spinning. It will wobble. I would lean toward the bent spindle. |
06-04-2009, 11:57 AM | #8 |
Under Construction
Never heard of a spring being upside down.. they are the same on both ends .... just need to be seated correctly in the pocket..... Bent or totally worn out balljoints. surprised the alignment shop didnt check for play in the suspension and say what you needed to have replaced....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-04-2009, 01:51 PM | #9 |
hopefully its the spring in crooked or upside down lol, if not that, well HERE WE COME DROP SPINDLES lol
06-05-2009, 05:43 PM | #10 |
you took out the shims or they did...
i may fool with mine in the am and early pm b4 niteride and mudbog...
06-10-2009, 06:43 PM | #11 |
Hellasick
Alignment shop did...just didn't want to mess with that part.
06-05-2009, 08:01 PM | #12 |
Watch out for your cornhole !
Fellas, you can't put the spring in upside down. It is pigtailed significantly on the top end. It wouldn't fit into the lower control arm notch if it were upside down.
06-06-2009, 09:58 AM | #13 |
i no i realize it now..may take it off and see today....will letcha know...pigtail'd end goes on top correct?
06-06-2009, 10:40 AM | #14 |
67-72 parts collector,…
Can you take some pics to help us understand what is going on?
06-06-2009, 11:20 AM | #15 | |
The spring itself has absolutely nothing to do with the alignment anyway, so that can't be an issue.....and certainly the alignment place checked for a bent wheel?
Exactly how did you "swap from drums to discs"? I am going to assume stock spindles because of your mention of "drop spindles" as a potential cure? ...so did you swap the control arms or ball-joints in this process? Entire crossmember? You stated that the wheels came from a fender-bender, what about your swap parts?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
