06-02-2009, 06:20 AM | #1 |
How hard is it to redo the gauges?
I was thinking about replacing the old gauges in the truck. Some work some don't, the gauge cluster looks to be setting in the dash wrong. Kind of like it don't fit. How hard is it to make your own? Does anyone have a how to on this?
06-02-2009, 07:10 AM | #2 |
yeller
Re: How hard is it to redo the gauges?
Mine
http://www.73-87.com/7387garage/inte...ge_surface.htm Swervins http://www.73-87.com/7387garage/inte...s_recessed.htm Dash mounted http://www.73-87.com/7387garage/inte...ashmounted.htm
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-02-2009, 07:58 AM | #3 |
Low & Fast!
Here is mine. And you can go to my blazer build to see more.
06-02-2009, 09:43 AM | #4 |
06-02-2009, 10:11 AM | #5 |
These are Equus Guages. They were inexpensive from Kragen (before O'reilly took over and ruined them). These guages were easy to wire in and have been fairly accurate. Basically all I did was to modify the guage housing for the new guages and made a mount plate for the speedo and tach. Pretty easy overall.
http://67-72chevytrucks.com/vboard/s...d.php?t=331910 |
06-02-2009, 09:42 AM | #6 | |
Wires worry me. I hate them. But I really hate ugly gauges. |
06-02-2009, 02:20 PM | #7 |
profeshinaly unimployed
Dash mounted
http://www.73-87.com/7387garage/inte...ashmounted.htm[/QUOTE] IM DOIN THIS NOW that junk looks awesome does any one here have that done?
"having mud flaps is like asking for a smaller trophy" |
06-02-2009, 03:24 PM | #8 |
I thought of that one, but to be honest I didn't like it too much. Mainly because the stock gauges look like crap, I want them gone.
06-02-2009, 03:30 PM | #9 |
oh i ment like im replace the rest of my gauges but just add some extra ones there
06-02-2009, 07:39 PM | #10 |
Arrived on a Pale Horse
If your truck is as nice up close as it looks in the teeny tiny avatar pic, I'd PM captkaos and throw in a set of Dakota Digitals...provided you can spare $650.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
06-02-2009, 10:09 AM | #11 |
6.0 powered square
here's mine
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
06-02-2009, 10:15 AM | #12 |
6.0 powered square
if you like diamond plate
06-02-2009, 11:13 AM | #13 |
The mechanic part of me tells me this is easy, but the dyslexic part of me looks at all the wires in the dash and hyperventilates lol..
So what I’m thinking is if I buy a set of oil, water, volts, tack and speedO I should be able to use the wires that come with the gauges and basically rewire them. I shouldn’t need to mess with any of the old wires. I should be able to just move them aside and feed the new wires to their right places. The only thing that I see that would be an issue is the power to them (fuse box). Should I use the original or buy a separate box? I want to make this as easy as possible. I don’t think making the gauges fit the bezel will be too hard. So I guess I’m looking for ideas on how to wire up these things. |
06-02-2009, 12:37 PM | #14 |
My wiring is kind of a mess. If I had more time I would redo it. I learned alot about making harness' with re-wiring my truck. Maybe when I transfer I'll clean it up.
Speedo, Tach, Fuel and Volt guages all need acc power, ground and the "input". For the inputs I used the stock fuel guage wire, the acc power for the volts, installed a new tach wire and the speedo cable. Also there are the lights for each guage which is a grouund and the feed of the dash light circuit. I know my write up isn't the greatest. The wiring really isn't too bad and its eaier than my description makes it. I can help over the phone if that might help. |
06-02-2009, 02:07 PM | #15 | |
Evan B. |
06-02-2009, 03:27 PM | #16 |
I used a new tach wire. The tach came with 3 different wires for the tac signal and and is adjustable for 4, 6 or 8 cyl. I used the stock speedometer cable. It bounces a little between 30 and 35 but it's been good overall. I forgot the end of it didn't connect right onto the back of the speedometer. It just kind of sticks on there.
06-02-2009, 10:29 PM | #17 |
In the Forgotten far North.
Here's mine...
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
06-02-2009, 10:32 PM | #18 |
06-02-2009, 11:09 PM | #19 |
Happy to be here
Well he could tell you....but then he would have to kill you...
06-02-2009, 11:13 PM | #20 |
06-02-2009, 11:17 PM | #21 |
Here is mine, front pic only, sorry about that.
06-03-2009, 10:10 AM | #22 |
06-03-2009, 09:59 AM | #23 |
Dang Ble, I just went through you cluster thread. You did one hell of a job. It would take me months to do that. I'm not the sort of guy that says I can't do something unless it's true. I'm pretty good at a lot of things, but what you did with the wires just puzzles me. That's why for me it would just be easier to replace all the gauges and run new wires. Well I think it would be.
06-07-2009, 12:20 AM | #24 | |
10-23-2009, 12:49 PM | #25 |
Hey 78bo - how did your project turn out? Get the gauges in and working?
