Old 06-05-2009, 09:19 AM   #1
locab36
locab36's Avatar
Brake porportion valve question....
Getting ready to do some brake work on my Panel Truck. It has power brakes but doesn't have the 'Power' feel. I have a feeling that it has man drum brake porportion valve. It was converted to 5 lug and the hoses are routed correctly. All the brake lines have what looks to be factory bends w/rock guards. The porp. valve is on the front crossmember in front of the PS gearbox. Kinda like the later 73 on pickups. Is this where its supost to be? The pics I've seen have the porp valve off the side of the master. Any info will help....
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 06-05-2009, 11:53 AM   #2
Burbinite
Re: Brake porportion valve question....
http://www.67-72chevytrucks.com/vboa...d.php?t=241722
Check out this thread. It has pics of the correct porp. valve. Yes, it should be off to the side (driver's) and supported only by brake lines.
Hope that helps you out!
1972 GMC 4x4 Suburban F&R A/C
1978 Pontiac Trans Am 400(Z) all stock
Burbinite is offline   Reply With Quote
Old 06-05-2009, 03:19 PM   #3
locab36
locab36's Avatar
Lots of info there. My brakes work just seem stiff. I will try some booster tests I saw on that one link. I did have to lengthen the brake rod as the pedal was too close to the floor and didn't rest on the rubber bumper. Even w/the threaded end there wasn't enough adjustment. Got some grease on the pivots too, that seemed to help some. Still don't understand why my combination valve is on the front crossmember. Looks factory w/all the clips and rock guards. Someone went to a whole lotta trouble if it was changed. The brown brake trouble light wire is still up by the master.
John
Locab36
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
Old 06-06-2009, 01:08 AM   #4
Suburban 72
Suburban 72's Avatar
Check for kinks in the lines as well. I had a kink in the line to the back brakes and the braking felt stiff. The kink was behind the bracket that holds the hard line to the rubber line.
Ben
'71 C10 Longbed
Suburban 72 is offline   Reply With Quote
Old 06-18-2009, 04:25 PM   #5
locab36
locab36's Avatar
Replaced front hoses and all is back to normal. Normal power feel in the pedal and stops straight now too:-)
Locab36
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
Old 06-18-2009, 06:19 PM   #6
mbgmike
More often then not the hoses are the culprit. Nobody replaces them as they should. The inner liner collapses on them. Glad you got them fixed.
mbgmike is offline   Reply With Quote
Old 06-18-2009, 06:24 PM   #7
mbgmike
And yes the prop valve was usually on the firewall by the mc but whose to say some plants may have put it down lower. Here is a pic of an unmolested truck
