06-05-2009, 09:56 PM | #1 |
Keep Your Nose Clean
CPP tubular transmission crossmember
I just installed the CPP tubular transmission crossmember and am having difficulty fitting the 700R rubber mount. I looked on the CPP and it doesn't show the 700R as one of the transmissions for the tubular crossmember. Does anyone have a CPP trans crossmember running a 700R. If so, what mount can I use on it and where do I purchase it? Thanks. MisterE
06-07-2009, 08:57 PM | #2 |
1970 C10
Re: CPP tubular transmission crossmember
I had the same issue, i believe i used a turbo 350 mount but did have to modify the mounting holes to the crossmember, but as i put it in i didn't have any of the factory frame holes line up with the crossmember holes, did your holes match or did you drill new holes?
Thanks! |
06-07-2009, 09:07 PM | #3 |
I have the cpp tranny crossmember but I have a th350 it went on like a glove.....you might have to modify it..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
06-07-2009, 09:56 PM | #4 |
Too many projects
You could try a PowerGlide mount, that's what I'm using for my 700R4 on an original tranny x-member in my Chevelle.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
