Old 06-06-2009, 01:15 AM   #1
AllenKarber
Disc brake Non-power master cylinder question
I've installed a manual disc brake master cylinder on my '64 C10. Do you have to swap brake pushrods when doing this swap,or is the one on my truck the right length and bore size??
AllenKarber is offline   Reply With Quote
Old 06-06-2009, 09:13 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Disc brake Non-power master cylinder question
It kind of depends on the master cylinder. Is the current pedal and rod assembly able to reach the necessary travel of the piston?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-07-2009, 01:01 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I used the 'corvette' ms/cyl and bolted it right on. If your pushrod is too long your brakes will drag when driving.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
