Old 06-07-2009, 09:13 PM   #1
austex66
austex66's Avatar
Firewall pad install trouble
Can anyone offer up and firewall pad install tips? I am haveing a hell of a time with it. It has been a PITA, and its almost in, but there has got to be a "trick"...
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug
waltshow.com/Chevy
austex66 is offline   Reply With Quote
Old 06-07-2009, 10:12 PM   #2
ChevySixty6
ChevySixty6's Avatar
Re: Firewall pad install trouble
I agree it's a PITA. Just go slow, and if you need to, back off and chill awhile, then go back to it. Just bend along the pre-made seams to match the contours of the firewall. If you need to, check out some fo the members interior shots, to see which way the bends need to be. It took me a few trys before i got it just right.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 06-08-2009, 07:31 AM   #3
jason65
Registerd User
jason65's Avatar
Unbolt your heater box and fuse block and gas pedel. Just stay cool and work it.
jason65 is offline   Reply With Quote
Old 06-08-2009, 09:24 AM   #4
ratskin
I ended up throwing my POS away, and used butyl mat with foil-faced jute pad. Covered the entire floor & firewall with one piece of Ozite carpet.(64 Suburban) Looks better, and does a much better job of stopping heat and sound.
ratskin is offline   Reply With Quote
Old 06-08-2009, 11:55 AM   #5
austex66
austex66's Avatar
Well I did unbolt everything except the gas pedal, and I guess that is one of the PITA items. I am going to try again tonite to get the rest of the fastners in and staighten it out. I guess having rammat, and exsolite down doesn't help the fittment...
waltshow.com/Chevy
Old 06-08-2009, 11:24 PM   #6
ChevySixty6
I used several screwdrivers stuck in different holes to help get where it needed to go, then put in the plastic drive-in fasteners. I didn't drive them home all the way, until i was sure of the fit.
