06-07-2009, 10:02 PM | #1 |
Member of the longbed union.
Crossmember diffrence
What is the diffrence between the 63-72 and the 73-87 front crossmember? I have a guy that wants to buy a 73-87, but mine is a 64.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
06-07-2009, 10:10 PM | #2 |
60-66 Nut
Re: Crossmember diffrence
If you're talking about just the front suspension crossmember, there isn't much difference. One thing that I can think of is that the holes for the lower control arm shaft U-bolts are smaller, and there are tabs for the brake hoses on the early models. Other than that they are the same as far as I know.
06-07-2009, 10:25 PM | #3 |
That's what I was thinking I have a 64 front crossmember, and theres a guy looking for a 73-87. I think just because he wanted to swap to disc brakes. not sure though.
06-08-2009, 12:55 AM | #4 |
Resistance is Futile
The control arm bushings are solid. The brake hose goes on the front on the 73+ set-up. Didnt know if you were talking about all the associated pieces, too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
