Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 06-07-2009, 10:53 PM   #1
Captainfab
60-66 Nut
Power Brake Booster Adapter Bracket
Here is the latest version of the power brake booster adapter bracket that I've been making since 1993. This bracket is fabricated from laser cut 10ga mild steel and fits 1967-'72 Chevy and GMC Pickups, Suburbans and panels and is 100% bolt on using holes already in your firewall. The booster side of the bracket has a 3 3/8" x 3 1/2" hole pattern. Boosters with this pattern are commonly found on S10's and full size pickups, Suburbans, Blazers and Tahoes from 1988 to at least 1998. Of course you will have to join the booster pushrod to your stock MC pushrod that attaches to your brake pedal. This can be done by either threading both ends and using a coupling nut, or by just welding them together once you determine the correct length.
I have had the original version ('63-'66) of this bracket on my '66 Suburban and have driven over 120,000 miles with no issues. I have also installed these on a couple of local pickups with good results as well. If you are wanting to add hydroboost to your pickup, Suburban or Panel I also offer a mounting plate for the hydroboost HERE
The price on the bare steel brackets is $59.50 plus a flat $16.25 shipping in the US. If you are located elsewhere contact me for shipping charges. You can also get this bracket in a satin black powder coat for an additional $9.00. Mounting hardware is included. This pricing is not current and up to date.To place an order post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
THE '71-'72 FACTORY BRAKE BOOSTERS ARE NOT COMPATIBLE WITH ANY OF MY BOOSTER BRACKETS
Old 06-07-2009, 10:57 PM   #2
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
More pics......
Old 06-07-2009, 10:59 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice part. Looks like it would clear up alot of space for us BBC guys.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-08-2009, 12:43 AM   #4
Captainfab
60-66 Nut
Thanks Josh
Old 07-27-2024, 10:15 PM   #5
STP67-72
STP67-72's Avatar
Originally Posted by Captainfab View Post
More pics......
I bought one of your 67-72 booster bracket. I’m just now installing it. I have a new 9 inch booster. But I mocked it up today. It all fits good. But after putting colomn in, The shift lever hits booster. I have a list of boosters that you put in box. I have a new 8 inch I’m going to use. Curious if you have a new updated list of boosters that will fit with auto column. I was getting ready to order a couple more. Thanks Steve
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 07-27-2024, 10:22 PM   #6
STP67-72
STP67-72's Avatar
More pics......
68 Chevy swb fleet
07 SS Trail blazer
Old 07-29-2024, 01:53 AM   #7
Captainfab
60-66 Nut
Sorry but I do not have a definitive answer that you are looking for. Over the past 15 years a few people have had an interference issue with the column shift on the '67-'72's, but no one has ever let me know just what size booster will work. I am not in the business of building trucks for people so I have no way of finding that answer on my own. My specialty is the '60-'66 trucks. I do own a '68 but it is a 4 speed truck. I know what works on a '60-'66 with the factory auto column shift. I would have thought that a 9" booster would have cleared. A 10" will on a '60-'66.
Old 06-08-2009, 09:11 AM   #8
72SWBChevy
72SWBChevy's Avatar
NIce work. I will have to place this on my list of "to buy" items. Craig
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 06-17-2009, 09:56 PM   #9
Captainfab
60-66 Nut
Bump for those having trouble finding this thread
Old 08-07-2009, 12:15 AM   #10
Captainfab
60-66 Nut
Haven't bumped this in a while......
Old 12-20-2009, 12:23 AM   #11
Captainfab
60-66 Nut
Checkout the December deal over in the 'Vendor Marketplace' HERE
Old 05-25-2010, 12:40 AM   #12
Captainfab
60-66 Nut
Bump.......
Old 05-25-2010, 02:42 AM   #13
hddavis
do you know if this bracket and the 88 to 98 booster set up will work on a 70 c10 with drums on all four
hddavis is offline   Reply With Quote
Old 05-25-2010, 11:06 PM   #14
Captainfab
60-66 Nut
Yep, no problem. You just need a power brake master for a drum/drum system. The one I use on my Suburban is a power brake master for a '67-'70 truck.
Old 05-26-2010, 03:13 AM   #15
hddavis
i read on here somewhere that the factory man drum master would work
Old 05-26-2010, 01:49 PM   #16
hddavis
do know if that is so
Old 05-26-2010, 11:50 PM   #17
Captainfab
60-66 Nut
I have not tried that. On the manual master cylinders, the bore in the backside of the piston is deeper than on a power master cylinder. So I suppose if you wanted to make a new pushrod to go between the booster and the master, it could be done. But I wouldn't mess with it. A rebuilt power master isn't that much $$
Old 06-11-2010, 08:33 AM   #18
mbrekke
if I use your bracket on a '72 will a booster out of a '92 bolt right in or will I need to modify the rod that connects to the pedal. Do I just pm you to buy a bracket?
mbrekke is offline   Reply With Quote
Old 06-11-2010, 11:01 PM   #19
Captainfab
60-66 Nut
Since a '92 full sized truck booster falls within the '88-'98 range, yes it will bolt up. The pushrod will need to be lengthened to reach your pedal. Yes, just send me a PM to purchase.
Old 11-03-2010, 11:35 PM   #20
swamp rat
swamp rat's Avatar
Is this for trucks without a booster altogether? or are the newer boosters that much better than the one on my 72?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-31-2011, 05:49 AM   #21
Sultan88
diagnostic
Spam
Sultan88 is offline   Reply With Quote
Old 02-22-2011, 12:59 AM   #22
stich626
ttt just so I can find this later
stich626 is offline   Reply With Quote
Old 04-13-2011, 06:54 AM   #23
mcmlxix
Collector of Projects
mcmlxix's Avatar
x2
Rich
1972 K5 Blazer CST Click HERE
Old 05-06-2011, 09:05 PM   #24
jocko
jocko's Avatar
Captain,
Received the bracket in the mail today - beautiful piece of gear, thanks very much.
For everyone else's reference - I bought a 75 Impala Booster and a 67 C10 Drum/Drum master cylinder to use on this - all the parts fit together with no mods or hole drilling. Part arrived vacuum packed and is PC'ed beautifully. (I have not mounted it to the firewall yet - only speaking of the mc-to-booster-bracket so far, but I know it will fit the firewall also).
I'll post the install if I ever get off these #$%^&* cruthces... but here are the O'Reily's part numbers if you're interested (btw, same stuff/store as "Kragens"):
67 C10 Master Cyl ($18.99 + $10 core) Part # 10-1329 (Note: the part number on the website appears to be incorrect (13-1329) – when I called O’Reilly’s, they didn’t list this part number – they list the MC under 10-1329, and the receipt showed this as well – I think the website must be either a typo or an old part number. But what I bought looks exactly like what is in the link and its part # at O’Reilly’s is 10-1329)
75 Impala Booster ($104.99 + $10 core) Part # 54-81002
Thanks again Captain, appreciate the quick deliv and great craftsmanship.
Old 01-19-2016, 09:40 PM   #25
62LS1
62LS1's Avatar
Captain,
Just so you know, the 13- part number is a new MC from Cardone. The 10- part number is a reman MC from Cardone. I don't believe O'Reilly sells the 13- new versions. I worked for Cardone for 20 years.
Too many dreams, too little money.
62LS1 is offline   Reply With Quote
