Replacing door hinges???
The hinges on the driver's side are sagging pretty bad on my '79. I'd like to replace them and the strikers at the same time.
Is LMC the only place to get them? Should I get the hinge bolt kit to go with it or can I find what I need at a hardware store? Do you have any tips?
Evan B. |
Happy to be here
![]() Join Date: Mar 2000
Re: Replacing door hinges???
Are you sure it's the hinges that are sagging? Have you replaced the hinge pins and bushings? I have seen hinges wear out, but normally it's the pins and bushings that cause the sagging doors.
No, I'm not sure. Thanks for pointing that out. I'll try the "Door Hinge Pin Kit" first and see if that does the trick.
Evan B. |
![]() Join Date: Jan 2002
ok- I need the hinge pin kit as well- aer they easy to change out??? any tips on hanging them out???
2003 2500 HD Crew Cab 1965 GMC K10 1972 Chevrolet k5 blazer |
you can get hinge pin and bushing sets at shucks around here.not sure what the store is called in your area? it's more than likely just the bushing's.i had to do mine as most guy's have.30 plus year's on them.especially the driver's side.
" Never look up a dead dogs butt." ![]() Last edited by boatpuller; 06-09-2009 at 10:45 AM. |
Sb 400 club
hing replacement is easy
Pins can be more of a pain but not that bad at all. I can't remember exactly but i think the hing has at least 3 bolts that hold it on the cab and two that hold it to the door. two of the cab bolts are on the outside and the other needs to be accessed threw the govebox door area. Kinda a pain especially if you have ac. As for the bolts I would be suprised if they need to be replaced. Mine have all been fine and our trucks get rusty here.
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Would I just be better off removing the hinges to replace the pins rather than trying to do it with them on the truck?
Evan B. |
Next project: 1970 K10
Pin & bushing replacement from the FAQ section:
http://67-72chevytrucks.com/vboard/s...d.php?t=216479
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
