Old 06-10-2009, 01:35 PM   #1
tinkerdad
Power steering gear box
I’m gong to a pick and pull to get a power steering gear box. What other vehicles will have the same one as our trucks?
Thanks,
Kelley
tinkerdad is offline   Reply With Quote
Old 06-10-2009, 11:37 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: Power steering gear box
Up to '78 will fit just fine, the later ones (not sure when they started) will be "quick ratio" 2.5 turns vs. 3 turns. '79 to '87 will work, but are "metric o-ring" fittings instead of the older flare fitting. These are easy enough to convert and use your factory lines.
http://67-72chevytrucks.com/vboard/s...d.php?t=242458
I think this change was in '79, easy enough to tell at the yard.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 06-11-2009, 07:18 AM   #3
tinkerdad
Thanks,
Kelley
