06-10-2009, 08:56 PM | #1 |
Painless Harness, where to put the ECM?
I'm installing a Painless harness in my '72 Blazer and I need to install the ECM but I don't want to put it in the way of something else so I'm looking for any tips on where to put it.
I was thinking behind the gauge console under the dash....but not sure if that is a good spot or not. Wires are really long enough to put it behind the glove compartment. Anyone done this already that can give me the benefit of that experience?
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
06-11-2009, 12:21 PM | #2 |
Re: Painless Harness, where to put the ECM?
I have mine stuffed up above the heater controlls, there was an "open" area up there on mine.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
06-11-2009, 07:30 PM | #3 | |
I've been wondering the same thing. I'm getting ready to start wiring the MPFI up and was gonna ask you where you put yours. |
06-11-2009, 08:21 PM | #4 |
sharp as a marble
I have a customer with a 57 Chevy. LS2,6 speed trans, SMOKIN HOT high dollar ride. The builders put the pcm under the dash, on top of the heater /a/c hoses. I do not reccommed putting it somewhere wher you could not have easy access to it in case of a failure. IN the 57, I will have to discharge the A/C, remove the heater hoses, etc to get it out.
My money would be in the glove box. You have a big center console to keep your stuff. You could also put it in the engine compartment? Think that might be kind of hokey, though. Maybe under the drivers seat Last edited by cparman; 06-11-2009 at 08:22 PM. |
06-12-2009, 08:47 AM | #5 |
I will be puting mine under the glove box liner. It seems to be about the only place I can hide it from sight, and still have it accesable. And being my wheeling truck, hopfuly above the water line.
06-12-2009, 10:41 AM | #6 | |
Happy Friday~!!
06-13-2009, 06:26 AM | #7 |
I posted in your build thread before I saw this one, sorry for the repeat.
I also used a Painless harness for my ECM and had enough length to mount it on the firewall behind the glove box, which I cut down for future access. If it reaches the gauge cluster area, seems like it should reach the glove box area... |
