Old 06-15-2009, 12:16 PM   #1
vegaschevy
sheet metal thickness
I have a courtesy light, door lock holes, gas filler hole, and various holes on the fire wall that will need to be filled. What are you guys using for thickness or gauge of steel? and what kind of steel?
i have some air operated snips and gonna really start working on the cab this week.
vegaschevy is offline   Reply With Quote
Old 06-15-2009, 12:24 PM   #2
vegaschevy
Re: sheet metal thickness
dont ask me how this ended up in here, i was in the general 67-72 section
Old 06-15-2009, 01:08 PM   #3
dough_boy
dough_boy's Avatar
in most cases we try to use the same thickness metal as the panel we are working on. also we use cold rolled sheet metal for any shaving that we do in our shop. by useing the same thickness as the metal you are working on it displaces the heat evenly and helps to keep from warping the metal as much. just make sure to use small spot welds and dont over heat the metal when welding it so that it doesnt warp.
dough_boy is offline   Reply With Quote
Old 06-15-2009, 01:40 PM   #4
vegaschevy
any idea what the factory cab, doors, firewall is?
Old 06-15-2009, 01:42 PM   #5
Shane
Shane's Avatar
Just a guess on our year-model trucks, but most body panels of this era are 18 gauge sheetmetal ...
Shane is offline   Reply With Quote
Old 06-15-2009, 01:49 PM   #6
vegaschevy
Thank you thats a good place to start then.
Old 06-15-2009, 01:50 PM   #7
dough_boy
dough_boy's Avatar
yea id say between 18 and 16 gauge. on most of the panels. you can pick up small peices from lowes and home depot but i recomend just going to a supply store and buying a whole sheet. you will come out cheaper in the long run.
Old 06-15-2009, 03:08 PM   #8
vegaschevy
I actually do not need very much so maybe that is the way to go. Ill price it out and see. I have a few small holes and the panel across the front for when I remove the trim rail
Old 06-15-2009, 03:15 PM   #9
Shane
Shane's Avatar
Oddly enough, 18 gauge is actually quite hard to find at Lowe' / Home Despot / Tractor Supply ... for some odd reason they seem to skip this gauge. At least around here it seems to be the case.
I try to keep an old beat up hood or other dented body panel around for such reasons ... drag 'er in to the shop ... cut off what I need & then beat it into submission and the desired shape.
Old 06-15-2009, 04:42 PM   #10
vegaschevy
I do have two doors that are quite rusted on the bottotm that came with my rust free cab. Maybe I need to make some panels form these....
Old 06-15-2009, 04:54 PM   #11
dough_boy
dough_boy's Avatar
yea its always good when ya can save some money like that and it should be the exact same thickness
Old 06-15-2009, 08:45 PM   #12
protrash64
Resistance is Futile
protrash64's Avatar
My local metal place has a remnants rack (their garbage) that people can purchase for reduced retail prices. Its a budget friendly way to roll.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
