Old 06-16-2009, 08:18 AM   #1
rodney fisher
brake conversion
Hey I was wondering if the power disc brakes on a 1974 chevy c10 could be converted over to a 1969 chevy c10 that has drum brakes?
rodney fisher is offline   Reply With Quote
Old 06-16-2009, 01:41 PM   #2
rodney fisher
Re: brake conversion
Does any body know?
Old 06-16-2009, 02:36 PM   #3
Hart_Rod
Hart_Rod's Avatar
It will work. The best way (and easiest way) to do it is remove the entire front crossmember from the donor truck. You will also need the master cylinder, power booster and proportioning valve.
Hart_Rod is offline   Reply With Quote
Old 06-16-2009, 05:45 PM   #4
rodney fisher
Thanks I appreciate your help!
Old 06-16-2009, 10:37 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Welcome Rodney! You can search the FAQ's section for related stuff.There will be way more info than you need but you should find a write up on exactly this swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-16-2009, 10:46 PM   #6
rodney fisher
Hey the 69 has only two brake lines coming off the valve proportioner one for the front and one for the back. And the 74 has four lines coming off the valve proportioner for each wheel. Can I use the valve that is on the 69 or do I have to use the one off the 74 and run four lines to each wheel?
Old 06-17-2009, 10:49 AM   #7
rodney fisher
Hey I searched the faq's but I didn't find anything that would help
Old 06-17-2009, 12:14 PM   #8
71tahoe
71tahoe's Avatar
You should definitely not use the 69 valve. Not sure how to adapt the 74 to your application. You could use one from a 71-72 or an aftermarket disc/drum.
71tahoe is offline   Reply With Quote
Old 06-17-2009, 12:35 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
You will need to use the valve off of the 74 along with the front lines associated with it.
http://67-72chevytrucks.com/vboard/s...d.php?t=209956
http://67-72chevytrucks.com/vboard/s...d.php?t=215980
These should answer any of your questions.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-18-2009, 07:56 PM   #10
rodney fisher
Hey I just now noticed that my 69 has six lugs and the 74 has five. Is there a thread on that conversion process? The other 2 threads on the brake conversion has helped a lot thanks
Old 06-18-2009, 09:09 PM   #11
71tahoe
71tahoe's Avatar
Specifically what conversion. Take the 74 disc and make them 6-lug or make the rear end 5-lug? LMC, CPP, and ECE all carry bolt on 6-lug front discs and any 71-72 truck rear end will swap into yours.
Old 06-18-2009, 09:47 PM   #12
rodney fisher
So I can just buy 6 lug rotors
Old 06-18-2009, 09:50 PM   #13
rodney fisher
So I can take the 74 disc that are 5 lug and just buy some 6 lug rotors from a parts store?
Old 06-18-2009, 10:14 PM   #14
rodney fisher
Do I just tell them that its for a 74 with 6 lugs
Old 06-18-2009, 10:32 PM   #15
71tahoe
71tahoe's Avatar
I don't know of any parts stores that carry them. Strictly specialty aftermarket:
http://www.earlyclassic.com/catalog.aspx?ProductId=205
http://www.classicperform.com/Store/...ruck/CP4R5.htm
http://www.lmctruck.com part # 34-3223 DISC BRAKE ROTOR
Old 06-18-2009, 10:51 PM   #16
myfirstcarwasa73trk
myfirstcarwasa73trk's Avatar
Here is what I am doing to have more pics if it helps
myfirstcarwasa73trk is offline   Reply With Quote
Old 06-18-2009, 11:24 PM   #17
cstm68
cstm68's Avatar
cpp has the 6 rotors that will work with the 74 parts its the same rotor just 6 lug instead of 5
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 06-19-2009, 02:42 PM   #18
rodney fisher
Is cpp classic performance parts
Old 06-19-2009, 09:43 PM   #19
cstm68
cstm68's Avatar
yessir
