06-16-2009, 02:27 PM | #1 |
My 59 fleetside build
I have been working on this truck for about 1 year, so i have a lot of pics. I'll start at the beginning. The stripped and painted frame. With a 76 Nova subframe grafted on.
The front suspension assembled I used a 10 bolt posi off a 66 chevelle. Replaced everything and installed I think 376 gears (it's been a while, and this is a before shot). Installed a 4-link setup. I'll post more later. Last edited by frmula505; 06-16-2009 at 02:30 PM. |
06-16-2009, 03:32 PM | #2 |
Thanks 'til you're better paid
Re: My 59 fleetside build
Frame looks nice! Any before shots of the truck?
-Luke 1950 Chevy AD 3100 pickup 2000 GMC Sierra 1970 Jeepster Commando |
06-16-2009, 03:53 PM | #3 |
The truck was given to me by my dad when I was in high school. I've rebuilt it a few times, finally decided to do it right.
Here is a picture of it in the early 80's (I'm on the right) |
06-16-2009, 05:09 PM | #4 |
Cool project. Keep us up-to-date on the progress you make.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
06-16-2009, 05:13 PM | #5 |
Nice truck! Frame looks good too.
06-16-2009, 06:47 PM | #6 |
I didn't take any pictures of the disassembly, I took it apart about 5 years ago. I was going to do a partial build and of course got carried away. When I had it partially apart I replaced the cab corners, and cab running boards. These were taken after the subframe was installed and I was taking the frame apart.
I'll scan some of the old pics I have of it's many phases over the years. |
06-16-2009, 06:54 PM | #7 |
looks like the pictures didn't show I'll try again.
06-16-2009, 07:32 PM | #8 | |
06-16-2009, 08:18 PM | #9 |
Looks good so far!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
06-17-2009, 12:24 AM | #10 |
Nice looking truck. Kim |
06-17-2009, 08:53 AM | #11 |
"What brand of four link is that? I have never seen one that uses the stock crossmember and shock mounts. What are you going to use for a panhard bar?"
It's a Heidts kit I had bought about 10 years ago for it. I have a new panhard rod also from Heidts. It got lost over the years I've had the kit. I've modified the kit a bit to fit using the stock crossmember. I had to make a small adapter plate to fix the angle of the coilovers. Plus gives me a lot of options for the ride height adjustment. before After I still have to install the panhard rod and C-notch the area over the rear end. I know I should have done it before I painted the frame, but I do the painting myself so just a little more work. While I had the cab off I repaired all the holes in the floorboards. No rust just old seat and shifter holes. Truck was a California truck, so very little rust. Just the cab corners and a little in the hinge pockets. I also braced the running boards, and undercoated the bottom. |
06-17-2009, 11:34 AM | #12 |
I noticed that too, here are my thoughts. For a while I ran air shocks to my stock mounts and found the stock mounts were bending when I had the camper loaded and the shocks taking most of the weight off the springs. They are not designed to support the weight of the bed and frame, just for shocks to dampen the rearend movement. You are essentially transfering all of the weight supported by the spring shackles (note how many rivets and how they are distributed) to the two rivets holding the shock brackets. I would look at adding additional material to the shock crossmember the full width while everything is accessible.
06-17-2009, 01:46 PM | #13 |
If you notice I have a small aluminum spacer between the coil over and the crossmember. When I do the c-channel, I am going to weld some 2x2 square tubing both from the c-channel plate and to the crossmember. Eliminating the original mounting points.
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
06-20-2009, 11:56 AM | #14 |
DAMN this is one thread I'll be watching closely. We have a 58 GMC short fleetside in tear down right now and has a 79 Nova subframe in it from a previous owner. It's nowhere as clean of a job as you have done. Could you post some closer pics of where you joined the frames together?
06-23-2009, 01:57 PM | #15 |
Here is a shot of the engine and transmission installed. I used the March original style pulleys. I couldn't use the serpentine type because of the type of power steering pump these old big blocks use. They use an external reservoir.
This angle shows the pump, and the alternater brackes I had to use. In this one you can see the way I set up the power brake master cylinder.
06-23-2009, 09:10 PM | #16 |
Nice work.
What did the brake and master cylinder come off of?
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
06-24-2009, 09:16 AM | #17 |
The pedal assembly came off the 76 Nova doner car. That is the car I got the subframe from. Of course I bought a new master cylinder. Also the Nova firewall was not vertical, it was at a slight angle. I had to cut a pie shaped section out of the booster mount and reweld it. When I first installed it, it looked like it was pointing to the sky.
06-28-2009, 03:28 AM | #18 |
Did U Have steering box issues with headers and who's header did u use?
Then again the Wife could be RIGHT "Just cause I Drink alot of Bud that does'nt make me WISER" |
06-29-2009, 09:41 AM | #19 |
I still haven't run my steering column. From what I can tell I am going to have to use a couple of steering u-joints, but there is room. I used the Hooker competition Headers. They have 2" primaries, and 3.5" collectors. They are big. I ordered them for a early Chevelle /Nova/Camaro. To match my doner front clip. I'll try to post some close up pics. i did have to trim my Upper motor mount ant my a-frame a bit, bot places I remove non structural metal. I wanted to make sure I had enough clearance.
06-29-2009, 02:36 PM | #20 |
I welded the door handle opening shut, and removed the wind breakers. I plan on installing pop door kits and electric solid windows.
06-29-2009, 05:56 PM | #21 | |
Nevertheless, do most guys that use them install some kind of fail-safe device in the event of dead battery? Hidden manual cable actuators or something? I read someone (?) say to route them to a box under the truck then put an old fashined padlock on the box door in the event of emergency. Sounds good to me, but is anyone really doing that? |
06-29-2009, 03:47 PM | #22 |
Looks good! Keep it up
06-29-2009, 06:01 PM | #23 |
Oops, I forgot to ask: On those door handle weld-ups, did you use a sheet metal plug or did you do the little-by-little built up weld to close them? I'm wondering if a hole that large can be filled that way without heat induced warp? Sorry for all the questions. "Enquiring minds want to know!"
07-06-2009, 09:10 AM | #24 |
I am going to use pop door solenoids. And yes it will have a manual release cable. I have no need to lock it up. I will probably never leave it parked alone. And it will have an alarm that will go off if the door is opened without being disarmed. I welded small pieces of metal to fill the door openings.
