06-17-2009, 08:59 PM | #1 |
Active Member
72 4x4 disc Brake help.
I only had a front right brake catching and it pulled badly to the right. So I put new calipers on my disc and new brake pads. I bled the line and no luck. So I put a new master cylinder in and still no luck. Does the proportioning valve have to be hooked up correctly even if the rear brakes aren't working and there is a hole in the line?
Hole in the line. My pickup
_________________________________ 1972 Chevy SWB 4x4 350 4speed |
06-17-2009, 09:08 PM | #2 |
Next project: 1970 K10
Re: 72 4x4 disc Brake help.
Are you driving and trying to diagnose a brake problem with a broken rear hard line? I think I would fix the obvious problem first, the broken line, then worry about it pulling to the right.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-17-2009, 09:11 PM | #3 |
Active Member
No the truck isn't being driven. When I drove it home I noticed the brake pulling so I thought I would fix it before driving anymore but I can't seem to get the calipers to close down. Is there any way to see if the brake booster is bad?
06-17-2009, 09:36 PM | #4 |
I'm a little confused by the pics your prop valve. Both the front and rear brake lines should be coming out of the prop valve, and both ports of the MC should go to the prop valve.
Edit - I just went and looked at my 72. There is only one line coming out of the prop valve for the front. It runs to the frame, then tee's off to each front caliper. So if one side of grabbing and not the other, and you have already replaced both calipers, then you probably have a blocked/plugged hard line after the tee. Since the prop valve's job is to divvy up fluid to the front and rear appropriately, the rears should to be hooked up correctly to the prop valve and the broken line repaired to properly diagnose everything.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 06-17-2009 at 09:45 PM. |
06-17-2009, 09:50 PM | #5 |
Here is a pic of the MC/PV on my 72. It's missing the short line from the front port of the MC to the prop valve, but the rest is correct.
06-17-2009, 09:51 PM | #6 |
.....I am working on it.....
First of all, you need to have the rear brake line connected, you will lose all pressure there.
You prop valve should have two lines coming in and two lines coming out. The fron leaves the prop then to a tee on by the steering box then to each side from there. Then the rear runs along the inside of the passenger side frame rail to a tee before the rear axle then to each drum from there. Last edited by sandking; 06-17-2009 at 09:56 PM. |
06-18-2009, 05:29 AM | #7 |
I would bet that your problem with the front brakes is that one of the hoses is swollen shut inside.
Tim |
06-18-2009, 07:45 AM | #8 |
Active Member
Would inline tubes 10pc kit for disc brake lines for my 1972 short box be the way to go since I have a broken line and everything is so rusty I cant brake it loose?
06-18-2009, 11:04 AM | #9 |
I would suggest replacing all of your brake lines and connecting them correctly, then carry on from there.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
06-18-2009, 11:47 AM | #10 |
Without a doubt, this is much needed on this truck.
06-18-2009, 12:41 PM | #11 |
Project Junkie! Fishing Poor!!
I know exactly what your problem is. Someone has plummed one side of the front brakes through the proportioning valve and the other from the rear brake side of the master cylinder. This is all wrong!!!! They probably did that because it may have bad brakes on the rear, or mabe bad brake lines. I would hasard a guess that you will need all new brake lines and the proportioning valve to solve the problem. (Maybe new shoes and drums on the rear also) WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 06-18-2009 at 12:42 PM. |
06-18-2009, 04:40 PM | #12 |
Your calipers are on the wrong side, bleeder valve should be on top.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
06-18-2009, 05:13 PM | #13 |
Good call!! I did not notice that before.
06-18-2009, 06:50 PM | #14 |
I missed that one too..lol It wouldn't cause the pulling while braking though. I stand by my diagnosis. You can't have one brake line running through the proportioning valve and the other not. The fluid in the rear resivour (unless it is empty) has to be going somewhere. It definately isn't being lost out of the broken line, or you would see fluid all over the rear end. So that tells me that the line from the mastercylinder is not connected to it. (Again unless the rear resivour is empty) I think that he has the two lines plummed one to each caliper. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-18-2009, 09:27 PM | #15 |
Active Member
I have the master cylinder set up right but I need to replace some broken lines. Everything is so rusty it doesn't want to come apart.
So the calipers are on the wrong side? My rear broken line and the hose that I can't break loose from the broken line.
06-18-2009, 04:49 PM | #16 |
Doh, I never noticed that!!
06-18-2009, 09:32 PM | #17 |
The new line from the MC to the PV looks to be kinked in at least two places. I would have someone with a tubing bender twist one up for you, or buy the proper pre-bent tube.
I say replace them all right now. You don't want those rusty steel lines to fail when you need to hammer the brakes hard. The calipers are still on the wrong sides too.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 06-18-2009 at 09:33 PM. |
06-18-2009, 09:48 PM | #18 |
You really, really need to replace all of the brake lines in order to get this right. Broken and kinked lines will never work correctly and will sacrifice your safety.
06-18-2009, 09:57 PM | #19 |
Active Member
I planned on tearing the pickup all the way down to the frame anyways. Would you recommend inline tube for new lines?
06-25-2009, 10:49 PM | #20 |
Active Member
My work for the weekend.
06-26-2009, 09:14 AM | #22 |
Nice!
06-28-2009, 01:20 PM | #23 |
i was just going to suggest that!! did wonders for me- plus, there right around the corner from me.
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
