06-18-2009, 08:38 PM | #1 |
Gettin It One Pice At A Time
I am lost, I need help.
OK, a few days ago I was working on a Jerry rigged electrical work I did to a plug on my wiper motor. I used some good wire and couplings. I took my time and made all the connections tight. I went it to make sure the wipers worked and they didn't so I got to looking at the fuses and everything looked good. no breaks or melting. so I though that maybe I screwed up on my fix. so I cut it all up and Jerry rigged it just like I had it before. Still Nothing! so I went out and got a multi-meter and I checked to see if I was even getting volts to the wires at the plug. No suck luck. I tried it every which way I could think of. wiper switch on, off,and wash mode. I tried having the leads on both wires and both ways and tried having the ground, grounded to the frame. Nothing! so I thought, maybe its the switch! so I got it out and I had the ground, grounded to the dash. went to every connector and got nothing! I tried it with the ground on the black wire, nothing. tried it with the plugs on the switch and switch on. Nothing! So, NOW WHAT!!!! LOL the meter does work, battery is good and grounded good. I had it on the 12 volt setting. and the wipers worked before this started. I did have a question sort of like this in the electrical board. and didn't have many takers. thanks!
The plug on the left is the one I was working on. Here is the switch.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 06-18-2009 at 08:39 PM. |
06-18-2009, 10:07 PM | #2 |
Arrived on a Pale Horse
Re: I am lost, I need help.
Was the key turned to the on position (forward)?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
06-18-2009, 10:34 PM | #3 |
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
06-18-2009, 11:37 PM | #4 |
Do you have power at the fuse?
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
06-19-2009, 01:10 AM | #5 |
well, here is problem number 2 most of the names on the fuse block is gone. so I don't know which one it is. I pulled all the fuses out and they were good.
06-19-2009, 05:14 PM | #6 |
problem solved! I found a pic of a fuse box with labels and found out the fuse holder for the wipers.... well......didn't have...a fuse!
