Old 06-18-2009, 09:00 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What is this and what plugs into it?
Can anyone help me out here???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-18-2009, 09:06 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: What is this and what plugs into it?
Sorry, no help here. Is it part of the TBI harness?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-18-2009, 09:11 PM   #3
Keith Seymore
Keith Seymore's Avatar
What year truck? Where is it (the module) located? (Is that the left side kick panel we are looking at?).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-18-2009, 09:23 PM   #4
86 Jim Dandy
86 Jim Dandy's Avatar
I do Belive that is part of the steering column. Im sure some one will know whats its for.
86 Jim Dandy is offline   Reply With Quote
Old 06-18-2009, 09:26 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
its for the windshield wipers
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-18-2009, 09:32 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
That is the intermittent wiper module that is mounted under the dash just below the steering column. It has the wiper control switch wired into it from one end and the wire going to the wiper motor on the other end.
Old 06-18-2009, 10:11 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Its a 87 chevy harness and its in the cab. So it sounds like the windshield wiper switch should plug into it? correct?
MEMBER #6377
Project "7DEUCE"
Old 06-18-2009, 11:04 PM   #8
flamingbig10
6.0 powered square
the wiper switch it mounted on the turn signal lever on 84 on also the dimmer switch is also moved to column
Aaron
Old 06-19-2009, 05:49 AM   #9
D13
D13's Avatar
Yes the wiper wiring coming down the column plugs into it. And it slides onto some clips on the column. IIRC the end to the left goes to the left and th ewhole unit sits behind the lower column trim piece.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-19-2009, 05:55 AM   #10
Curly86
You want it there when???
Curly86's Avatar
It is the wiper delay switch
1986 Silverado Flatbed 400 SB with 350 turbo
1997 Ford Explorer with 302 mydrive to work ride
1978 Gmc Midas RV 21ft with 46,000 actual miles
2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow
Big Sandy Survivor 09
Trucks in the Blue Grass Survivor 09
TNCTC
Streetcruzin
Curly86 is offline   Reply With Quote
Old 06-19-2009, 06:26 AM   #11
Keith Seymore
Well...since I asked for clarification I may as well respond, too...
It's the module that controls the wiper delay (my '87 has the same thing).
K
1979-1986
1986 - 2019
