BlahBlahBlah
American Auto Wire
I just got my wiring kit from Musclerodz. I had no idea it had so much stuff in it. The box it comes in is the size of a briefcase. I just did a cursory look through it (didnt wanna lose stuff). This thing is first class all the way, even has a new ignition switch with keys.
When I get to the point of putting it in Ill post up some pics. From first look through Id highly recommend this set up, and get it from Musclerodz he sells it for a nice price. |
2WD Jimmy
![]() Join Date: Mar 2005
Re: American Auto Wire
Which kit did you get?
BlahBlahBlah
Here is a link to the kit on his webiste
http://musclerodzstore.com/index.asp...rodID=806&HS=1 Hmm I just noticed that said Chevelle...I really need to wear my glasses more often. It is the same kit except its for truck...lemme see if I can find it. Ok, try this...http://musclerodzstore.com/index.asp...ROD&ProdID=689 Last edited by CG; 06-19-2009 at 01:53 PM. |
I'll try to contribute...
Also, a pic of how much the firewall needs to be cut.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
454 MAKES IT ROAR
Why do you need to cut the firewall OldCreek....is it not a direct replacement?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
"THE GREEN GOBLIN"
That kit looks good and very impressive BUT I am No Fan Of Cutting the Firewall at all Someone has to come up with a better way to do it. I am sure I aint the only one that wouldn't cut the firewall Thats just like cutting the Dash for a new stereo Wouln't do that neither but thats just me.................
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Under Construction
My buddy's shop uses AAW exclusively..... nice product for sure, what kit did you use the 69-72 retrofit?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#8 | |
Leo.
Leo70 ![]() 1970 Chevy Shortbed 1956 Chevy 210 Post 1963 Chevy Impala SS Rag..SOLD! ![]() |
![]() Join Date: Jan 2007
I was looking to get this down the road - got any pix of the setup - the only pix online are the same one (the layout pic).
Yeah, I got my "suitcase" also. Impressive. And, all the different "sections" are separated in their own bag.
Any hints on the best way to cut the firewall? Mine's already painted.
#11 | |
I was fortunate to have the engine out when cutting the fire wall so just zipped a bit off the right side and bottom with the cut off wheel - you don't need to cut much but could see it being a bit tricky from inside - maybe a die grinder?? They give you a nice template to follow... |
454 MAKES IT ROAR
CG, get that camera out now, we need pics right from the git-go. How's it look in the briefcase size box?
It is NOT a direct replacement. That bummed me out also. Painless is NOT a direct replacement either. I'm not sure what is.
Also, you have to drill two new holes to mount the fuse panel. I don't know why they cant make direct replacements....
#15 |
I personally do not want a direct replacement. I want to be able to add an alarm, power windows, door locks or poppers, have better access to stereo wire, etc.
Its a little hole in the firewall, hell I am getting ready to trim my drip rails, smooth my firewall, etc. Seems like a no brainer to cut a small hole. |
#16 |
That does seem strange that they would go through the hassle of making it so complete - and then ask you to cut the firewall to install it...interesting...
#17 |
The firewall needs to be cut for the newer blade style fuse panel - its just larger.
I think this kit and most others are just using a standard 'new style' somewhat generic fuse box that unfortunately has a bigger opening than the old glass fuse one. Personally I'd much rather cut the fire wall a bit to modernize the electrical system and add the ability for power locks/windows, alarms, amps, upgrade headlights etc. If you're doing a restoration and have the fenders off or the motor out its really quite easy. If not it might be a bit more work but certainly not more than an hours job to cut it from the inside my $0.02 Last edited by 100mph; 06-20-2009 at 02:49 PM. |
#18 |
BlahBlahBlah
If your wiring is fine, or if your doing a 100% resto don't use an aftermarket set up like this.
But if you're like me and have stripped every last spec of wire off your truck and all you have is a bare shell this is a perfect way to go. Or maybe your 40 year old truck has had quite a few previous owners that have managed to cobble the heck out of the wiring over 30 plus years, and you are having constant electrical problems...this would be a good way to go. Personally I couldn't care less if someone cuts their dash, cut a big ol round hole in there and install flashing neon smiley face ![]() But like we always say...To each their own...If we all agreed on everything, what a boring world this would be =) |
#19 |
You can't consider this kit a direct replacement anyways since you have to terminate alot of the connectors yourself. Original fuseboxes are not like most the other fuse boxes used during the 60's and 70's thus requiring to have to trim the hole. Many cars using this same box do not require trimming the firewall.
You can buy direct replacement harness kits, but you are going to pay twice as much as this kit costs and will not handle upgrades very well, and still use the glass fuses. Kit was designed to provide an electrical system for a vehicle with anticipated upgrades, providing safe operation of those components and ease of installation
Mike Redpath |
#20 |
It says 69-72
Will there be a kit for the 67-68? It looks like a very complete kit and if it work for a 67 I will get one when I replace mine.
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby Last edited by Wilson_; 06-21-2009 at 01:33 AM. |
#21 |
Kit will work for the 67-68 trucks with some concessions. Main one being it does not come with the turn signal connectors for the 67-68 trucks. Also suppose to be an issue with the e-brake placement but have not confirmed that problem yet.
Mike Redpath |
#22 |
Guys,
I have talked to Ron Francis via e-mail and he says the weakest area is the factory bulkhead. It was originally put in by manufactures to cut down on wiring mistakes. He says when he first got started he worked , I believe at a dealership doing work around splices ,because so many cars and trucks had short problems in the area. If you look at alot of vehicles , you will notice a many are melted in these areas. Ron suggests using a flat plate and drilling wire holes thru the plate and using rubber grommets to seal them off. That way you can wire directly into the back of the fuse box. He sent me a wiring catalog with a lot of info about correct crimping and connections etc. He has also introduced a magnetic base fuse box that can be pulled out so you can work on it or replace fuses without having to get under the dash. I suggest going to his site and checking everything out. A lot of what he says makes sense !!! ![]() |
#23 |
I installed the under dash harness/fuse box today....PIECE OF CAKE! I agree with the plug 'n play comment.
#24 |
I talked with donny from AAW a few times. He swears up and down that you'll have issues with a 67/68 due to the box orientation, wiper location, and e-brake. This is the guy that designed the system so I take him for his word.
He suggested that if i want plug and play then they have a kit for that, it's $800 though! Same price for M&H, but you get all connectors and can choose HEI and alternator upgrades with it.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
