Old 06-22-2009, 02:34 PM   #1
Vendetta
Vendetta's Avatar
Question Axle swap question....
What is the difference between the dana 44 front axle and gm 12 bolt rear axels from a 68-72 truck versus the 44 and 12 bolt from the 73-87 trucks?
Can I use the axles from the 73-87s on my 72 4x4? Thanks for any help.
Vendetta is offline   Reply With Quote
Old 06-22-2009, 02:40 PM   #2
b454rat
Re: Axle swap question....
68-70 will have drum brakes and maybe closed knuckle. Could be off a few years.
73-up will be discs, and just about a bolt in. Lower shock mounts are little different, and if truck has drums, will need to change M/C for a disc/drum setup.
The rears are pretty much the same, 68-72 have a narrower spring mount width. 40.5" over 73-up 42.5". If your going 3/4 find a rear out of a 1 ton truck, it will bolt right up.
Been awhile since I swapped mine, so could be other stuff I missed.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-22-2009, 10:14 PM   #3
Mike C
Mike C's Avatar
The 71-72 axles have smaller u-joints in the knuckles and their are some differences in the outers as well with the seals and bushings. The 73 and up is a better choice strength wise, but it's not a whole lot.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-23-2009, 11:45 AM   #4
Vendetta
Vendetta's Avatar
Thanks for your help guys. I may just stick with overhauling my original axles.
