01-04-2003, 01:57 AM | #1 |
GYRO GEARLOOSE
Quick question on 3/4 ton rear install.
On my '68 C-20, I aminstalling the 'pumpkin' on an Eaton-Type axle. Does that side of the differential get a gasket? I cannot tell from the looks of the old surfaces.
Thanks...
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
01-04-2003, 03:43 AM | #2 |
Jostrans68
It had one on mine I just put mine back in and I used silicone it will set a few months anyways so should be ok.. I have never used gaskets on either side of any of my others..My .02 Jack
[CGTW Member former 67-72 now with a 96 silverado |
01-04-2003, 04:19 AM | #3 |
GYRO GEARLOOSE
thanks, think I'll use ultra black, and use the gasket I bought on the backside, might as well use it.
01-04-2003, 05:25 AM | #4 |
Silicone II Window & Door sealant from Home Depot (blue, black and gold cauk tube). I use it on my differential and when I install intake gaskets. Zero leaks.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
01-05-2003, 12:04 AM | #5 |
There is supposed to be a thin paper gasket in front and a thicker gasket in back. Same bolt pattern front and rear, too.
Just as if I knew what I was doin' |
