Old 06-22-2009, 06:46 PM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
so is this an "Expensive" sound?
it does sound like a loose valve but I am sure they are all tight and adjusted right. I checked some of them. the motor does have a miss in it. I just did the plugs, gaped them at 45*, I "think" the wires are OK. I did notice before that when it would click, it would miss then when it stopped it was OK. it sounds like its coming from up-top. also, what is that thing that is attached to the passenger side manifold? there is a rod that disappears in the back of the motor. could that be causing the clicking? the rod behind the *canister* is loose.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 06-22-2009, 07:12 PM   #2
79gmcc15
79gmcc15's Avatar
Re: so is this an "Expensive" sound?
oh, I meant to re-phrase the last question. I know the rod that is connected to the "canister" is not making the noise. what I am wondering is what it was connected to, could be?
RIP ELJAY
Old 06-22-2009, 08:10 PM   #3
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
sounds like the rockers need adjusted,The little vac canister is for a vacuum operated heat riser the rod should be connected to a valve in the exhaust between the manifold and exhaust pipe
powerdriver 1958 is offline   Reply With Quote
Old 06-22-2009, 08:22 PM   #4
79gmcc15
79gmcc15's Avatar
to adjust them I can just start it up and loosen one till it starts clacking then tighten till its not then give it a 1/4 turn right?
RIP ELJAY
Old 06-22-2009, 08:43 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Yep...
tvblazer78 is offline   Reply With Quote
Old 06-22-2009, 08:45 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
And you may have a bad lifter for it to just start doing that. Did you change oil here in the past week or two?
Old 06-22-2009, 10:28 PM   #7
79gmcc15
79gmcc15's Avatar
yes I did, about 3 weeks ago.
RIP ELJAY
