Old 06-22-2009, 10:12 PM   #1
pritch
pritch's Avatar
Why are these front X-member nuts copper plated?
When I disassembled my Panel, I noticed that on the ten 3/8s bolts that hold the front crossmember on, the nuts seem to be copper plated. The bolts seem to be un-plated, just the nuts are. These are lousy pictures, but I'm just wondering if this is normal or if someone had changed them out at some point.
The bolt on the right I cleaned up a little on a wire wheel.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 06-22-2009, 10:26 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Why are these front X-member nuts copper plated?
that's normal.. can't help you on why they did that..
Livrat is offline   Reply With Quote
Old 06-22-2009, 11:42 PM   #3
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
You're sure they are copper? That's weird. I'm wondering if it's some kind of a "grounding" reason. It seems that copper would be way too soft for nuts. Hmmmm
prostreetC-10 is offline   Reply With Quote
Old 06-23-2009, 12:34 AM   #4
Skirkpat
Skirkpat's Avatar
They might be plated, but i have not heard of copper, Cadmium maybe? like a brake booster?
Skirkpat is offline   Reply With Quote
Old 06-23-2009, 12:41 AM   #5
westofb
I really hate wet sanding!
westofb's Avatar
maybe brass nuts like on exhaust manifolds to keep them from siezing up?
westofb is offline   Reply With Quote
Old 06-23-2009, 05:22 AM   #6
JimKshortstep4x4
Copper plating of steel nuts is a way to reduce corrosion and it was fairly common for certain applications.
It looks like the nuts were well protected, judging from your picture.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-23-2009, 08:55 AM   #7
prostreetC-10
My Carbon Footprint
[QUOTE=JimKshortstep4x4;3374967]
Jim[/QUOT
....and it's always a good idea to protect your nuts!
Old 06-23-2009, 11:44 AM   #8
tranz am
tranz am's Avatar
dito
[quote=prostreetC-10;3375100]
Jim[/QUOT
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 06-23-2009, 10:20 AM   #9
Skirkpat
Skirkpat's Avatar
I can see where this is turning, so I will refrain from adding my "02" since.
But it is hard with comments like this.
