06-23-2009, 12:59 PM | #1 |
power steering fittings
I have the late model o-ring type power steering hose fitting for the high pressure hose. I want to use the factory power steering box and hoses for the 1968 year trucks. I need the old style fitting to install in my late model pump. Do any of you guys know where to find one? I have exhausted all local sources that I know of. THANKS
06-23-2009, 01:10 PM | #2 |
Under Construction
Re: power steering fittings
When we did our serpentine install, I changed the fitting on the back of the PS pump with a large cresent, installed the '67 fitting on the new style pump and used the original PS hoses. so you could reverse that, go to a junkyard etc, or possibly the parts house and ask about a replacment fitting for a '94 ps box. it will screw in the back of the '68 and you can utilize the new hose
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 06-23-2009 at 01:13 PM. |
06-23-2009, 01:25 PM | #3 |
Go to your local circle track shop.
They have fittings (inserts) to convert o-ring to flare. Or online at Smileys or Speedway Motors. Mick |
06-23-2009, 01:27 PM | #4 |
06-23-2009, 01:28 PM | #5 | |
Middle-aged Curmudgeon
Any pump from the late 70's back, car or truck, has the right valve in it. It's 1-inch across the flats and just unscrews out of the back of the pump. Very easy to swap. Any junkyard should have several cars or trucks you could pick one off of.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
06-23-2009, 01:29 PM | #6 | |
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
06-23-2009, 01:34 PM | #7 |
I need to do exactly what you did. I can't find an old style fitting to install in my late model pump so I can use factory hoses. Local junkyards don't have anything old enough and the parts houses give me the "deer in the headlight" look when I ask about a replacement fitting.My truck did not have power steering so I don't have the old pump to rob the fitting out of. I have a few pumps , but all of them have o-ring type fittings.
06-23-2009, 01:41 PM | #8 |
P.M. me your address. I gotta make a junkyard run tomorrow anyway and I'll find one and mail it to ya.
06-23-2009, 04:00 PM | #9 |
now that is just too cool!
06-23-2009, 04:57 PM | #10 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
