what size is the nut or bolt
what size is the bolt or nut that is on the front of the engine where u can hand crank it so i can get it to true top dead center.. i can barely get fingers in there so...
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
My Carbon Footprint
Re: what size is the nut or bolt
Are you talking the crank bolt? I believe 3/4". Listen....you don't have to get it "that" close as long as the dist goes back in the same place.
oh i didnt know that .. my bad.. but i dont know because i yanked the old one out a few days before and im not sure if somebody turned the key so i was just gonna be safe then sorry
If it is a small block, it is a 7/16" bolt, fine thread, I think 24 threads per inch. The hex size should be 5/8".
Randy, West TN 67 Fleetside SWB L6 3 speed on column 84 Feetside SWB L6 3 speed on column yes, I like column shifts 99 Dodge 4X4 Ext. Cab |
