Old 06-25-2009, 08:00 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
15 inch 3/4 ton wheels?
did any trucks come with factory steel 15 inch 8 lug wheels?
our years , or others-
Or , are there any made on the aftermarket today?maybe a trailer wheel?
Old 06-25-2009, 09:24 AM   #2
ratskin
Re: 15 inch 3/4 ton wheels?
My 61 3/4 has 19.5 wheels, 3 piece, I believe. I haven't seen any others like 'em-I thought they were all 15 or 16 inch.
ratskin is offline   Reply With Quote
Old 06-25-2009, 09:41 AM   #3
padresag
I am running 15" on my 4 x 4. 8 stud. I had to use a 1/4" spacer on thr frts to clear the calipers.
when I 1st got my truck there were 36x15x15 on it 6 stud and when I bought new tires 33x12 1/2 x15 I still had 6 stud so when I went for larger axles I just changed the rims , ( i just went to the tire shop and bought them), I will be going to 16" soon as when I get new tires again I will be going skinnier
ron
padresag is offline   Reply With Quote
Old 06-25-2009, 11:16 PM   #4
Captainfab
60-66 Nut
It is common to have caliper clearence issues with 15 inch wheels in a 8 lug application. If I had a choice I would go with 16 or 17 inch wheels. The 16.5's are OK for normal use, but I've heard that they are slowly phasing out that size of tire.
Old 06-26-2009, 08:12 AM   #5
jonzcustomshop
1961 crewcab
weeellll... its not exactly for a truck aplication... I am in the dreaming/procurment stage of building a street legal,vintage stock car...
I have located a 62 chev 3/4 ton detroit locker, and I am thinking of using the whole setup,trailing arms coils and all. the fronts will probably be regular 5 lug 15 drum or disc.
Old 06-26-2009, 08:19 PM   #6
factorystock
factorystock's Avatar
Yes, 60 thru 65 3/4 tons used the optional 8 lug 3 piece 15" split rim from the factory. In mid 65 it was dropped for the new 2 piece 16" split rim. In, 1969 the 3 piece 15" was recalled, and GM replaced them with 15" 2 piece rims.All 15" GM 8 lug rims were split rims, never had 1 peice 15 rims. All 16" 8 lug GM wheels were 2 piece split rims up to 1973. In 1974, the new 16" one piece 8 lug wheel first became an option.Don't know all the aftermarket scene, but I am sure there where 8 lug 15" white spoke wheels made.
factorystock is offline   Reply With Quote
Old 06-26-2009, 08:26 PM   #7
padresag
15" white spoke are what I have and no problem getting them
ron
Old 06-26-2009, 08:57 PM   #8
jonzcustomshop
1961 crewcab
both of those optinons sound workable...
I will have to see if I can find the white spoke in a 10, or 12wide, or the split might work, becaue all I really need is the center to weld onto a wider hoop.
the 3 piecesplit? does that mean that there is a center, and splits on each side, and then the 2 is 1/2 a wheel, and the other sideis the split?
Old 06-27-2009, 12:44 AM   #9
Captainfab
60-66 Nut
I believe you can get 15" 8 hole wheels all the way up to 14" wide. A lot of offroad guys use 15" wheels......I personally don't understand why but they do.
Old 06-27-2009, 08:42 AM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Are split rims not illegal to use.?
Old 06-27-2009, 11:01 PM   #11
factorystock
The 15" 8 lug pre 66 and the 17" 8 lug pre 69 were 3 piece split rims, wheel plus 2 piece ring on outer side. The only one recalled was the 15" because Chevy made the mistake of putting a 15 tire on a 3/4 ton truck. People overloaded these trucks and tires and wheels blew. The simple solution would be to order a larger 17" rim with a higher capacity 17" truck tire. Many salesman were at fault for not asking or knowing what people were doing with their trucks. Split rims are a common sight on heavy duty local trucks still today. They are not illegal in California.Most all heavy duty split rims are the 2 piece design from the late 60's and 70's.Sure they need a more expierenced person to correctly asseble them, but America was built with split rim trucks, and was a very common site on heavy duty trucks up to the mid 70's. I am not pushing split rims, since the tubeless tire and 1 piece rim is more pratical and economical in todays world. But, a split rim with bais truck tire always has a tougher look.
Old 06-28-2009, 06:30 AM   #12
aerotruk63
aerotruk63's Avatar
According to my GM parts book there was a 17.5" x 5.25" single piece tubeless tire rim option 8 lug. There was also a 6 lug version C,K and P model available, I'm looking for the 6 lug.
Old 06-28-2009, 08:59 AM   #13
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
The split rims are legal but a lotta shops are not doing them because of insurance problems,At least I have been told that by a couple of tire shops around KC
powerdriver 1958 is offline   Reply With Quote
Old 06-28-2009, 10:38 AM   #14
factorystock
The 17.5" 1 piece wheel ( 8 lug ) was the standard wheel on 3/4 tons and was common.The 17.5" 1 piece wheel ( 6 lug ) was an optional wheel on 1/2 tons and very uncommon. The 6 lug version was a very low production wheel and the best chance of finding them would be on a original government owned 4x4.
Old 06-28-2009, 04:39 PM   #15
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Jon, I got a set of 15" 8 lug white spokes. You need them?
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
