06-25-2009, 08:46 PM | #1 |
Trans Swap?
I currently have a 72 Shortbed with 350 motor and 350 Turbo Trans 3 Speed Auto and 3.73 gears. I would like to put some sort or 4 speed automatic with overdrive. Anyone make this swap and can tell me what trans you bought. I am also planning on baggin the suspension so I was wondering if anyone knows of the clearance issues with the newer trans??
06-25-2009, 08:50 PM | #2 |
I am a Referee of life.
Re: Trans Swap?
Welcome to the BB.I haven't done the swap but some here have.Many use the 700R4 and really like it.Your rear gear will also play a part in the best choice.
Look thru the FAQ's section and you will find a thread on the 700R4 and maybe others.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-25-2009, 10:33 PM | #3 |
Re: Trans Swap?
You might look into a 200r4. They are the same length as a TH350 so you can re-use your driveshaft, I just had to move my crossmember back to the next set of holes in the frame, bend the lines a little, get some brackets to install the T.V. cable, run wiring to lockup the converter and I was on the road. I have 4.10 gears so having overdrive is great.
06-28-2009, 01:39 AM | #4 |
Re: Trans Swap?
I just did this swap about 2 weeks ago. Still trying to get the bugs worked out but it's going to work great.Had to shorten the drive shaft about 3". Moved the cross member back about 2" I think. In my case I had to modify my shifter linkage but not really a big deal. Only trouble I'm working on right now is getting the torque converter wiring hooked up. Doing this on my own but I guess there are places you can buy the wiring harness and directions for hook up.I do love this setup though. Now I can drive 75mph at about 2300-2400 rpms. Much better then before. By the way my rearend gears are 3.73 if you're wondering. Good luck!
07-04-2009, 12:22 AM | #5 |
Re: Trans Swap?
When I wired the lockup converter the only issue I had was the 4th gear lockup switch. On some the pressure from 4th causes the switch to ground the wire, on mine it opened in 4th. If this is the case you need a relay wired so when the switch un-grounds it will complete the circuit to allow the converter to lockup. If you have a junkyard close you can get plenty of relays cheap (sometimes free!). Just find one that is open when the ground and power are going to it and will close the circuit when the switch loses ground. I hope this helps someone, I was really puzzled when the converter locked up in all gears but 4th.
07-04-2009, 08:56 PM | #6 | |
Re: Trans Swap?
Duke |
