turn signal problem?
hey guys I thought someone might be able to help me with my turn signals. I got in the 66 this morning and found that when I use either side they both flash like 4ways. I just did the bed swap. when I reinstalled the lights and wiring I made sure the grounds were good. and my wiring is in good shape no nicks. any thoughts would help.
60-66 Nut
Re: turn signal problem?
Did they work correctly before the bed swap? If so then I would recheck all the wiring you delt with in the swap
Size Matters
Well I don't have a diagram of a 66 but I'm thinking the turn signal switch is the most lilkely culprit?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
I am going to try removing and repluging the wires when I get home. the turn signal cam and assembly is only a year or so old so hopefully that is not the culprit.
Size Matters
Just doin a little research to try and help ya cause I ain't got nothin better to do ('cept work). You don't have a hazzard switch do you? Also, is your turn signal switch an aftermarket/add on accessory?
I appreciate the help no it's a faactory style in column turn signal assembly. no 4ways. I am really hoping that I just crossed a wire when I put it all back together.
Size Matters
I tried finding a wiring diagram online but couldn't find a good one with a factory turn signal switch that I didn't have to pay for. You don't happen to have one do you?
Resistance is Futile
Make sure your lite buckets are grounding.....I had a hell of a time getting my tails to work right. They will do all kinds of crazy stuff when not hooked up and grounded correctly.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
![]() it sounds like you have a bad ground and it is back feeding.
I will look into the grounds tomorrow I got called back to work for a sewer line backup so no checking it out tonight. I appreciate all the responses and advice the wiring diagram is great need to save that just in case.
I have a color '64 diagram around here somewhere.....I'll look and report back
#12 | |
thanks for all the replies. It's ben raining almost every evening so I haven't been able to look at it but I will sometime this week and let everyone know what it was.
