Old 06-30-2009, 04:42 AM   #1
oldspowered67C10
rear sway bar
Installed a street rod style rear sway bar, what do you guys think?
oldspowered67C10 is offline   Reply With Quote
Old 06-30-2009, 06:10 AM   #2
63 & 64 Bowties
and a few others
Re: rear sway bar
Nice work. Looks like you've put a lot of time into it. Interesting choice on exhaust routing. It won't interfere with your bed panels will it?
Oh and, I think it's time to change the date on your camera
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 06-30-2009, 08:25 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: rear sway bar
Tell us more about it. Is it a universal kit, or did you build it from scratch?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-30-2009, 11:55 AM   #4
fastbagged68
fastbagged68's Avatar
Re: rear sway bar
It would have been better to make it as wide as possible. I made mine wider then my frame rails. Speedway Engineering has a ton of info on swaybars.
fastbagged68 is offline   Reply With Quote
Old 06-30-2009, 01:34 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: rear sway bar
I also noticed your panhard bar. You have the frame mount side on top of the frame. I am assuming the pictures are at ride hieght. If so, you want your panhard bar level to the ground, not at an angle like you have it.
It is best to run the longest panhard bar you can, to minimize side to side movement as it goes thru its travel. If you moved it to under the frame and ran it over to the pass. side trailing arm, you would have a much better setup and better handling.
My .02 worth.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-30-2009, 06:47 PM   #6
Inverter
Inverter's Avatar
Re: rear sway bar
The end links look to be about 2 feet apart.As stated earlier,the endlinks need to be much further out toward the wheels to provide any anti-roll benefit. Looks like the panhard was setup at full dump.
Speedway does indeed have good info and products.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 06-30-2009, 07:28 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: rear sway bar
I like project pics because they make me think........in this case I think I would flip that sway bar to behind the axle and under the frame use 2 hym joints (maybe front end hanger with the rubber) into the frame and make it long enough to be on the outside of the frame but inside the exhaust......that being said I would like to see how you got your exhaust out there????
all that being said I wounder if there is a way to make it double as a panard bar?? that would limit your left right movement ??? hmmmmmm
but by the look of the boxed fame you have other plans for this truck??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 07-01-2009, 06:18 AM   #8
oldspowered67C10
Re: rear sway bar
Its a universal weld together kit from Paul Hortons welder series out of Canada. They come in various lengths and this one is 26". Its a 3/4" bar splined at both ends. Actually the one from Speedway was the one I initially wanted but its been on back order forever.
Regarding the width of the bar, if you look at factory rear bars on trucks they are always narrower than the frame rails so I doubt it makes much difference and truthfully the merits of a rear sway bar on a truck where the vast majority of the weight in the rear is so low in relation to the height of the wheels is questionable at best and is really only for handling tuning rather than controlling body roll. Besides, since I have no room on the outside of the frame rails due to exhaust routing and out board mounted shocks this was the best compromise I could come up with so I went with it.
As far as the panhard bar goes, thats something that I had done long before I took the body off and it works well, only about 1/4" of side movement from full raise to full dump. Also keep in mind that while having the panhard bar level is good for controlling side to side movement thats by no means the whole story. If you raise the axle mounting point in relation to the frame rail(lowering the vehicle) you need to raise the frame mounting point as close equally as possible to maintain the geometry. Another tidbit of information is that a low mounted panhard bar will increase body roll in corners and will typically make the vehicle tighter(push) in the corners as well as making steering turn in a bit slower. While most of these factors dont really matter for most of us its still something to think about.
Ill post some more pics to show the exhaust routing as well as some other stuff to give you an idea of what direction Im going with the truck. Ive already done a coilover conversion on the front and am working on one for the rear as well as doing my best to increase frame rigidity.
Anyways, thankls for the input and heres the pics.
Old 07-01-2009, 10:21 AM   #9
SCOTI
SCOTI's Avatar
Re: rear sway bar
That's a great build right there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
