Old 06-30-2009, 01:38 PM   #1
swissarmychainsaw
Suspension Help 84 Shorty Silverado!?
Hey there, I'm new to the truck world, and this site. My Gradpa and Dad used to have Chevy and GMC trucks when I was a kid, so I thought it was finally time to do it myself!
I picked up a clean 1984 Silverado short bed, and it needs a few things.
307, R700r4, 115K miles.
On the freeway this thing bounces like a beach ball. Nice big slow oscillations.
I figured it needed shocks, so I went to Meineke and put on "stock replacement" Monroe shocks that were about $35 bucks each.
*NOW* On the freeway it bounces like a beach ball. The new shocks seem to make no difference at all.
I am no suspension wizard, but what did I just miss? I don't mind spending some money to make this right, but I don't want to waste it either.
So...I'm asking for some guidance here.
Thanks,
--Nick
swissarmychainsaw is offline   Reply With Quote
Old 06-30-2009, 02:56 PM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: Suspension Help 84 Shorty Silverado!?
coil springs do wear out, you can get a new stock height set for $60-75. Also, if your truck is not equipped with a front sway bar it is a HUGE (and necessary in my opinion) upgrade. I would start with the coil springs though.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-30-2009, 04:37 PM   #3
swissarmychainsaw
Sounds like a plan. Where did you get your sway bar from?
--Nick
Old 06-30-2009, 08:41 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
You can buy them aftermarket from several of our forum vendors. The most common approach is to locate a used one and bolt it on. The standard is 1" and 3/4 ton trucks, Burbs had 1-1/8".
What you will want to know going in is the "stands" for the frame clamps are riveted to the frame.
If you are staying at stock height, you will probably want to acquire the frame stands. If you plan to lower the truck, then you can use low profile stands offered by E.C.E. . If your going really low, you can just bolt the bushing clamps directly to the frame.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-30-2009, 10:37 PM   #5
SCOTI
SCOTI's Avatar
I think 'standard' is 1.0625". The 3/4 & 1-ton HD bar is 1.25". They're typically found under Suburbans & duallys.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-01-2009, 10:22 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Your the numbers guy so I won't question you, but I could have swore it was 1 1/8".
Articles-
"Refining Sierra"
Old 07-01-2009, 11:18 AM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Swissarmy, I have to throw this out here. After your shock upgrade, did you drive down the same freeway? It could be the road and wheelbase combo of your truck. I used to drive a fullsize Chevy and an extended cab S10....road just fine. I would go to work and get in a long-bed Ranger and it would be bouncing just like you describe, like a boat on a lake, on the same freeway. Mite be something to consider.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
