06-30-2009, 11:19 PM | #1 |
Which Pitman arm do you use for PS conversion?
When converting my 65 to a 1976 power steering gear box do I use a 1965 factory Pitman arm or could I use the much less exspensive 1976 Pitman arm?
06-30-2009, 11:51 PM | #2 |
Resistance is Futile
Re: Which Pitman arm do you use for PS conversion?
I believe its the newer pitman.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
07-01-2009, 12:29 AM | #3 |
60-66 Nut
Use the newer one that is for the power box.....and be sure it is for a 2wd and not a 4wd. Although if you happen to have gotten a 4wd box the 2wd pitman are won't fit.
07-01-2009, 12:36 AM | #4 |
yup use the newer one
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
