Old 01-05-2003, 11:26 AM   #1
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
Question 6 to 5 lug
my '68 still has the factory 6 lug rear end,
I have a 5 lug rear end out of a '71 that I,m going to switch in,
the question I have is : are the axles the same, spline, length, etc. I'm going to use the entire '71 rearend, as I believe it is a bolt in swap, but the question was brought up to me, and I didn't know the answer , if in fact you could just use the axles?
thanks John
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 01-05-2003, 11:38 AM   #2
crazy longhorn
Fabricate till you "puke"
The 71 diff is 1 1/2" wider than the 68, so the axle shafts wont bolt in, but the complete diff is a bolt in swap. good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
