07-01-2009, 12:47 PM | #1 |
Spindle Question?
How do you tell the difference from a drop spindle and a stock height spindle? All help is appriciated.
Thanks |
07-01-2009, 12:55 PM | #2 |
Re: Spindle Question?
Dropped spindles will generally have the spindle hub higher on the body of the spindle & the spindle hub for an OE unit would be located closer to the bottom of the spindles body. Make sense? Another suggestion is most mfr's will stamp p/n's on their respective parts. If there are any numbers, google the number & see what you get.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-01-2009 at 12:57 PM. |
07-28-2009, 03:29 PM | #3 | |
Kvn1011
i have been reading that Z'ing the frame 3 inches will allow you to lay frame on 24"wheels or 30" tall tires, now my question is, will three inch drop spindles do the same, without Z'ing the frame?? |
07-29-2009, 01:42 AM | #4 |
Kvn1011
3inch Z and 3inch drop spindles??
07-29-2009, 09:16 AM | #5 |
At that tire height, no, you can't lay frame w/a stock front suspension & 3" drop spindles. You can't lay frame w/a 3" 'Z' & stock spindles.
You need the 'Z' & the spindles (or a Dropmember & spindles).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-29-2009 at 09:17 AM. |
07-29-2009, 04:35 PM | #6 | |
Kvn1011
thats what i was wanting to clarify, after a month or so i will start on my 72 still studying and learning from you guys, thanks again!! |
Tags |
drop, spindle, stock |
