Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 07-02-2009, 10:09 AM   #1
blazer2007
cleaning al. intake ?
am trying to clean al. intake that is still on the truck,gets gas and dirt build up,trying to find something to clean it with without going to pressure washer.I want that new look back
blazer2007 is offline   Reply With Quote
Old 09-09-2009, 05:11 PM   #2
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
Talking Re: cleaning al. intake ?
Me too i have the exact same problem. Anybody out there Help, Help, Help!!!!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 09-09-2009, 10:10 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I have gone so far aas to use an aluminum wheel cleaner to clean the pores of the intake out. That was while it was on the motor. HOWEVER, you have to protect ANYTHING that is painted--due to the acid base.
Old 11-15-2009, 11:23 PM   #4
okndnx
try windex
okndnx is offline   Reply With Quote
Old 11-16-2009, 03:47 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
http://www.edelbrock.com/automotive_...cleantips.html
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-16-2009, 04:06 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Refer to this thread... I'm curious if these products could be used on an intake. Mudder, any experience?
http://www.67-72chevytrucks.com/vboa...d.php?t=369277
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-16-2009, 04:11 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This link too...
http://www.67-72chevytrucks.com/vboa...d.php?t=355684
-Nate
Old 11-21-2009, 07:50 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
I guess i'll try the purple power on my intake and post up before and afters . seems like the sand cast is rough , but i'll try it .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-24-2009, 10:05 PM   #9
Myself
I can tell you from experience that any of the degreasers will work great. BUT!!! Don't use them if you have a shiny carb. It will be dull grey after you're done. Undiluted simple green and a 1" paintbrush with the bristles cut down will work wonders. And it won't dull the carb.
Myself is offline   Reply With Quote
Old 12-25-2009, 09:15 AM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
The intake is not installed . I would also like to add some shine to it .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-25-2009, 10:29 AM   #11
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
i'M A DUMBASS?? so now how do you get your carb shiny again?? yep used the purple power and it peeeld the paint off the block too???
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-28-2009, 10:24 AM   #12
Myself
Easiest way will be to remove the carb, you might as well get it fully clean at this point. Use some Mothers aluminum polish (or similar), and painstakingly polish it back out. Q-tips will get you into all the little nooks, but a small felt cone on a dremel will get the job done quicker.
Old 12-27-2009, 07:29 PM   #13
mbgmike
I've used that a bunch. good for cleaning out the carbon and it will make the outside look better, Won't make it look like new however but better
mbgmike is offline   Reply With Quote
Old 12-27-2009, 07:27 PM   #14
mbgmike
Edelbrock reccomends some brand of Oxy clean stuff. Its on their website somewhere. Not sure if its for and installed intake however.
Old 12-29-2009, 10:36 AM   #15
Mudder
Mudder's Avatar
I also used a mag wheel cleaner on mine at one time. It worked but wasn't a perfect fix. I would not recomend it to anyone for just the reason stated above. The best and easiest way to clean one is take it off and sand blast it. Once you have it looking good have it clear coated.
You might keep one clean if you never drive your truck or you can go to one of these.
Mudder is offline   Reply With Quote
Old 12-29-2009, 11:23 AM   #16
piecesparts
I have done the clear coat thing and you have to be careful of the type of paint that you choose. If you "rattle-can" the paint, the clear coat will turn slightly yellow after time. I have gone to just getting the intakes powder coated with a silver flake and that lasts for a long time.
Frank
Old 01-11-2010, 11:16 PM   #17
ag1972
ag1972's Avatar
The best thing I have done to clean one so far is glass bead blasting. Be sure you are using glass beads instead of sand though, I have heard sand tears it up really bad since its much more abrasive. Many people thought I got a new intake after they saw it. Here is some before and after pics.
ag1972 is offline   Reply With Quote
Old 01-12-2010, 09:23 AM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That turned out nice ag1972, nice work!
-Nate
Old 01-26-2010, 10:21 PM   #19
250cows
250cows's Avatar
Plain vinegar and a toothbrush works pretty good!
250cows is offline   Reply With Quote
Old 01-26-2010, 10:24 PM   #20
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
If you have it off use acid ment to clean aluminum. For instance find a blue beacon truck wash and have them spray it with their aluminum acid. It will make it look like it was just bead blasted. Just don't leave it on too long or it can discolor in spots(Burn the aluminum and areas will be darker than others).
Ryan
1969 Chevy milk truck
Old 01-27-2010, 07:11 PM   #21
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
ok gotta ?
eagle one makes an etching mag wheel cleaner..
i use it on my aluminum fourwheeler motor
same for intakes?
will be trying it when I get my used intake (waiting for gentleman to take it off and swap with my steel one )
John
1999 Toyota Tacoma 4x4
Old 01-27-2010, 10:59 PM   #22
Dieselwrencher
I'm betting it would work on the intake as well.
Ryan
