Divorced 205
Will a divorced 205 out of a ford bolt into a chevy mount or are the cases differen't, Larry
Re: Divorced 205
some 205's have the torque bracket on the passenger side and some don't.. the other main support is actually from the large spacer connecting the tranny to the TC.. I think you're gonna have to get creative with a divorced unit though..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: Divorced 205
A Ford 205 is driver's drop while a GM is passenger drop. I am not sure what you are meaning by bolting into the mount, but they are totally different cases as far as mounting goes.
Tim |
Re: Divorced 205
I believe the number of splines on the input or output shaft is different in different applications.
Brad 72 Blazer CST 350/350/205 ![]() ![]() |
Re: Divorced 205
on married cases yes, divorced 205's should have 32 spline input and outputs.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Re: Divorced 205
Thanks for the input I just thought I'd change out the old case in my 62 for the 205 if the mounts were the same and I could find one, it looks like I can rebuild the old one for about the same cash so I may go that way, there isn't really anything wrong with it but a good refresh is never bad, Larry
Re: Divorced 205
I bought a divorced 205 from a 3/4 ton Dodge to replace my Rockwell with. It has the passenger side drop and looks like it should work well. I'm not going to start the project for a while due to lack of time, but it looks like all it will need is maybe some custom mounts. My Rockwell still works pretty well, other than the normal noises and leaks.
‘66 Suburban 4x4 LQ4/4L80e Dana 60’s ‘67 Camaro RS/SS convertible 350/700r4 ‘74 K10 Stepside 402/TH350 Last edited by k14burb; 07-04-2009 at 04:15 PM. |
Re: Divorced 205
the cases are backwards to one another. all the parts from a l/side drop will fit into a r/side drop case though. IHC and dodge both used independent r/side drop. dodge has oddball ujoint flanges(yokes) and should be changed over
ron |
