Old 07-05-2009, 08:19 AM   #1
AusMarty
Welding Saddles
We all know that if you weld new spring saddles to your rear that you can warp your axle housing, just wondered idf there are any guys that do his sort of work can enlighten us on how to do it the corect way ?
AusMarty is offline   Reply With Quote
Old 07-05-2009, 08:54 AM   #2
mbgmike
Re: Welding Saddles
We never had any problems welding them on and warping anything. If you are really concerned you can cool it if you want. I doubt if they did that at the factory. You can try with a helper to blow air on it or to go to extreme you can wrap it with copper tubing and run chilled water thru it. Thats a bit extreme though.
mbgmike is offline   Reply With Quote
Old 07-05-2009, 11:24 AM   #3
ratty 46
Re: Welding Saddles
Never had issues but ....... if it is a concern you can do a few things to "limit" the HAZ like wrapping cool wet rags a few inches away from the weld area & keep them wet. The heat will be drawn to them. You can also google search a material than is a powdered form & when mixed with water makes up a formable heat barrier that will do as the rags will.
I've MIG & TIG these onto a rear with no issues.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 07-05-2009, 01:37 PM   #4
Twisted Minis
Twisted Minis's Avatar
Re: Welding Saddles
You're over thinking this. Just burn them on.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 07-05-2009, 01:43 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Welding Saddles
Yep. Never had a problem.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-05-2009, 02:06 PM   #6
mbgmike
Re: Welding Saddles
Thats what we do.
Old 07-05-2009, 08:24 PM   #7
AusMarty
Re: Welding Saddles
Yeah I might be over thinking this,it's just that a guy up the road from me building a kit car had a problem doing it and because it was so close to the flange it couldn't be straightened, maybe he got a bit carried away with the welding
Old 07-05-2009, 09:20 PM   #8
Twisted Minis
Re: Welding Saddles
Even if it warped really badly right next to the flange, it could still be straightened. It would be more work, but still doable. I have straightened badly bent axles with heat and a narrowing jig. They where bent closer to the center. If it was out close to the flange, you could remove the flange, and re-weld it on a jig.
If you weld 360° around the axle tube, you will be less likely to warp it. But realistically, as long as you aren't welding an 1/8" thick axle on a 3/8" weld setting with no stops, I doubt you will warp an axle enough for it to matter. If you are truly concerned, any shop nearby that can narrow an axle should be able to get it back to within a few thousandths of being straight again. I assume you are running a 12 bolt, which is a vary common axle. Most shops at least have tooling to do GM 12 bolts and Ford 9" axles.
