Bed Wood Thickness
I'm gonna have some local (oregon) wood milled for the bed of my '66. Any of y'all know the exact thickness the plank should be? What is the width of each board? Are there step-by-step instructions posted anywhere?
Cheers, Gary Last edited by Sicboy; 07-05-2009 at 09:05 PM. |
Re: Bed Wood Thickness
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado |
#3 | |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
yes it is, i want to go ooutside the box and make all my boards the same sizes, itll look better IMO
I wouldnt have it any other way...CHEVROLET! ALL throttle, NO bottle!!! Theres NO replacement for displacement Current Rides 2006 Silverado ![]() ![]() Previous Rides 2003 Silverado 1992 Silverado Last edited by chevysbest92; 07-05-2009 at 10:53 PM. |
![]() Join Date: Sep 2006
3/4" thick.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#6 | |
Thanks. |
be very carefull about the thickness of your bed wood .if it is to thick your body lines wont match up,as far a making them the same width that would be a real job,i just finished putting a wood bed in my 66 and aligning the mounting holes and the space between the wood is a bear.my sugjestion is no matter what you put in prefit everything first before you put a finish on the wood
thanks justbad, will do
here is the kit i bought from classic truck parts complete kit cost about $700
for polished stainless and oak |
ouch, i already have the polishes stainless, im going to cut and varnish the wood myself, i have a woodshop here
The bed looks good in the picture.
If you want real good results. Wet the wood and let the grain rise and then sand it. I personally like the grain in wood. I am a carpenter so I guess that is why. I was going to use White Oak as it has a tighter grain the Red Oak and will hold up better outdoors. I still don't know what I am going to do for bedwood so it is a good thing I am far from that at this time.
Thanks for the info. Like I said, I'll be using local Oregon lumber. We've got a variety up here in the PNW. I'm considering using madrone. I too like woodgrain...I'm a woodworker.
i cant hammer a nail good luck
I'm sure most of the parts houses get there wood kits from MAR-K. I got all my bed parts from them and would recommend them to everyone. And if ya watch the parts forum you can catch some good sale's to boot.
#15 |
I build these beds all the time and recommend using the factory specs shown on Paul's GMC site. For the best results on your finish it is best to use a good marine varnish sealer with UV protection first. I like Pettit and recommend three coats. This seals the wood so your varnish will now build. Then use a good Marine Varnish with UV protection. I like Epifanes Easy Flow. I also recommend using a bronze wool or wet sand between coats once you start with the varnish. The bronze wool will not rust like steel. I would not recommend using any kind of water base materials at all. They just do not hold up. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
