Old 07-05-2009, 11:47 PM   #1
KIC
1960 GMC Burb
KIC's Avatar
64 4X4 Disc Brake Conversion
My next door neighbor has a 64 GMC 4X4 Suburban that he would like to convert to front disc brakes. Has anybody completed this without replacing the front axle ?
How about adding a brake booster to a 64 4X4 ? Any issues?
Thanks.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 07-06-2009, 12:44 AM   #2
Captainfab
60-66 Nut
Re: 64 4X4 Disc Brake Conversion
Is it a 1/2 ton or 3/4 ton?
I'm not positive on this, but I think the spindles are different from the closed knuckle Dana 44's to the open 44's. If so you'll need to find the disc brakes from a '69-'70 or so dana 44 with disc's. Hopefully someone will chime in that can verify that.
It would probably be easier to just switch the complete front differential. You'd just have to make sure to get the correct gear ratio. I don't know about in your area, but around here you just about have to give away a '70's vintage 1/2 ton Dana 44
As for the brake booster, that's easy with the bracket that I sell (see link in sig)
Old 07-06-2009, 07:47 AM   #3
62 short step
62 short step's Avatar
I have heard of a kit for the 3/4 ton closed knuckle axle, but nothing for the 1/2 ton. When I did mine I just changed the axle, it was the easiest thing to do.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 07-06-2009, 05:23 PM   #4
fixie
fixie's Avatar
I found one for the 1/2 ton a while back but it was like $1100.00 Dont recall where i found it
If it Aint broke tear it apart anyway
fixie is offline   Reply With Quote
Old 07-06-2009, 05:59 PM   #5
joe231
joe231's Avatar
I did some research on this awhile back for the wife's uncle....all signs pointed to a front axle swap.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-06-2009, 06:57 PM   #6
KIC
1960 GMC Burb
KIC's Avatar
Thanks for the info. It is a 1/2-Ton with the original axles.
If you changed the front axle would you have to change the rear axle to a matching "type"( manufacturer) of axle or could you just change the rear pumkin to match the gearing of the front?
How much "improvement" would adding a brake booster add to the braking of these beasts ?
1960 GMC Suburban
1/2 ton V-6
2003 Tahoe LT
Old 07-06-2009, 07:03 PM   #7
62 short step
If you change the front make sure it has the same gear ratio as the back. When I did mine i added a power brake booster also, you would not believe the difference it makes. Its like day and night!!
1965 c-10
86 chevy c/k 20
Old 07-07-2009, 06:37 AM   #8
duallyjams
duallyjams's Avatar
Front axle swap is the best and economical way to convert to disc brakes.70 to 87 all have disc and will fit your friends truck.On the power booster I would use captain fab bracket.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-07-2009, 12:30 PM   #9
70 Suburban
Rods
I have an axle from my 72 blazer. Leme know. And you can flip the bracket for the booser upside down on our trucks looks clean and bolts up.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
