07-06-2009, 11:50 AM | #1 |
Metal upper radiator hose?
My 71 has the metal upper radiator hose!Does anyone know why Chevy did this?Should I keep this or go to an all rubber hose?Thank You!
07-06-2009, 12:13 PM | #2 | |
Re: Metal upper radiator hose?
pics?
07-06-2009, 12:54 PM | #3 |
Mine does too. In fact I think all the 4x4s had that from the factory.
Not sure why.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-06-2009, 02:05 PM | #4 |
I believe this is how all 4wd came. Not sure if it was because of the length or something else. I have always used them on my trucks.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-06-2009, 02:33 PM | #5 |
Ive read that it came factory in 4wd's because of low gears, low range transfer case, could cause engine to run hotter which could cause upper radiator hose to swell and burst. I would keep it , if its in good shape.
07-06-2009, 02:58 PM | #6 |
What?
Here is mine.
It's off right now, since it is rotted out pretty bad. I have been searching for shops that can bend pipe to duplicate mine, but no dice yet since it has too tight of bends that most bending machines can't duplicate. (At least in my neck of the woods).
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-06-2009, 05:31 PM | #7 | |
Never Ending Projects
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-06-2009, 03:00 PM | #8 |
I just bought one to put on my 68 K-10... I want it for the originality..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
07-06-2009, 05:43 PM | #9 | |
They call me the Breeze...
I believe the metal tube was used on 4wd's only...
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
07-06-2009, 07:14 PM | #10 |
Thanks Guy's for the input!I think I'll keep it,if it is not rusting on the inside.
07-06-2009, 07:22 PM | #11 |
and if it is rusted then soak it in a chemical rust remover... then have it powdercoated (if that resists antifreeze!) or some other type of coating.
07-06-2009, 07:56 PM | #12 |
It was a 4 wheel drive only thing. The engine is set back closer to the firewall by quite a little bit on them to provide more clearance between the oil pan and front axle. Its also why they have a different/longer fan shroud.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. Last edited by chipflyer; 07-06-2009 at 08:24 PM. |
07-06-2009, 07:56 PM | #13 |
Well I guess I should use the one I have on my 4x4 Burban, I thought it was a Redneck engineered deal on my 69 3/4 ton truck I parted out.
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-06-2009, 04:05 PM | #14 |
I would think finding a used one would be fairly easy to do. If you need one I'm sure a board member has an extra.
