Old 07-06-2009, 03:42 PM   #1
Rob73-87
Rob73-87's Avatar
What type of TH 350 do I need ??
Hi,
I picked up a 1982 C10 shortbed but w/o engine and transmission...
Now I´m not quite sure, what kind of th350 I should get ...? Short tail or long tail ???
I have a 1984 longbed with a short shaft th350 and a segmented driveshaft, - but the short wheelbase has a "normal driveshaft"....
thanks for you input....
Rob
1982 C-10 SWB (soon dropped, 383ci, but restored stock appearance)
1984 C-10 LWB, dropped, custom paint
1996 Plymouth Voyager (Daily Driver "The Mule")
2008 Caliber R/T (Daily Driver)
Rob73-87 is offline   Reply With Quote
Old 07-06-2009, 07:35 PM   #2
Rob73-87
Rob73-87's Avatar
Re: What type of TH 350 do I need ??
anybody?
Old 07-06-2009, 08:34 PM   #3
Damien
Damien's Avatar
I'm pretty sure you need long tail shaft
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 07-07-2009, 04:26 AM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
short tail was stock for short bed th350. Long beds usually get long tail shafts with one piece driveshafts. If two piece driveshaft its usually short tail.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-07-2009, 09:27 AM   #5
OrangeAnimal
OrangeAnimal's Avatar
I have a 82 C-10 SWB and the Trans is a TH350C with a 9 inch tailshaft and one piece driveshaft. That is what you need. You can use the TH350 or the TH350C the difference is regular torque converter or the lock up type that is in the TH350C.
Do you have the driveshaft? If so measure it and let me know what the tube length is. I can tell you what will work with it.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 07-07-2009, 03:20 PM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
A buddy of mine has an 81 2wd blazer that came with a 9 inch tail housing th350c...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-07-2009, 05:08 PM   #7
truckincurt
if ur truck has a one pice drive shaft u need a t350 witha 9" tail ... being a short bed it should have a 1 pice drive shaft
diy or die
truckincurt is offline   Reply With Quote
Old 07-07-2009, 08:24 PM   #8
benoit454
Chris
benoit454's Avatar
we have an 84 short bed with a long tail and 1 piece DS and we also had a 76 short bed with a 3 speed on the tree, which a short tail th350 would have fit in place. measure your driveshaft and post the length of it that could help alot. or tell us what it had in it before.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-07-2009, 08:42 PM   #9
OrangeAnimal
Looks like we are all in agreement TH350c or regular th350 with a 9 inch tailshaft.
Old 07-07-2009, 11:00 PM   #10
asphaltburner
asphaltburner's Avatar
Yo! The long tailshaft seals the end of the tranny and contains the gears for the speedo. If you have a transfercase, IT seals the end of the short tailshaft tranny and the speedo gearing comes off of the tcase.
You'll need a one piece driveshaft and long tailshaft tranny for a two wheel drive truck.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 07-10-2009, 05:21 PM   #11
Rob73-87
Rob73-87's Avatar
well okay - so I need to get a long shaft (9") TH 350 then...
Today I measured the driveshaft as some of you suggested .... 140 cm from u-joint to u-joint that`s ~ 55" !
Will this work with a 9" th 350 ? (Just to make sure...)
thank y`all Rob
Old 07-11-2009, 09:33 AM   #12
moneyeater
moneyeater's Avatar
Hey Rob, wouldn´t it be smart to get an th700r4 or 4l60e tranny to get better mileage?What engine do you plan to throw in that truck?
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 07-11-2009, 04:08 PM   #13
Rob73-87
Rob73-87's Avatar
Volker
well I like the rigidity of those old TH 350....I know i would get better mileage with an overdrive tranny, but they are not that good for our high-speeds and so on.
Don`t get me wrong the TH700 is a very good transmission, - but I love th400s and Th350s...
And I think they work better with EFi cars and trucks not carbureted ones...?!
Rob
