07-08-2009, 11:24 AM | #1 |
Problems lifting 2wd
I have a 76 chevy 1/2ton and i want to do a 4 inch spindle lift but i cant find one. So i have been looking and i found one for a 88 chevy will it fit on mine or can i do something different to get 4 inches of lift?
07-08-2009, 12:46 PM | #2 |
Re: Problems lifting 2wd
They do not currently make a spindle lift for pre 88 trucks... that I am aware of. AIM did in the past but quite some time back and I have never heard anything good about them anyways. There are coil lifts available with tubular control arms but a spindle lift is the BEST way to keep steering geometry.
I have heard/seen people use the 88-98 4" spindle on pre 88 trucks. It does involve swapping a couple ball joints and I believe lower control arms. I have never done it or see a write up about it specifically for lifting a 2wd. Using the coils is ok.. it gets the lift but it puts the tie rods/ball joints a severe angles and also almost eliminates any down travel in the suspension. The design of the front suspension does not lend itself well to lifting. here is a thread with some pictures... for "inspiration".
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 07-08-2009 at 12:51 PM. |
07-08-2009, 01:11 PM | #3 |
05 1500 Crew Cab 79 K10 Scottsdale 71 K10/Custom 85 K30 CrewCab 72 Camaro |
07-08-2009, 01:56 PM | #4 |
In all my multi-tasking I forgot to post the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=176272
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
07-08-2009, 02:46 PM | #5 |
I ran a ball joint spacer and a moog 3/4 spring on the front of my 78 blazer. The set up yielded me 5" up and 5" down travel. I also had a simple shock hoop with with two shocks per side. The stock upper arms were tabed and they ran to the top on the hood
07-08-2009, 03:08 PM | #6 |
Do you have any pictures of this set up?
07-08-2009, 03:05 PM | #7 |
here is the problem with running lift coils.. Granted the truck pictured is sans engine, but it still demonstrates the problem when trying to get too much lift from a coil.
On my 82 I ran 1 ton front coils and could fit 32"s with a slight rub problem.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 07-08-2009 at 03:07 PM. |
07-08-2009, 08:39 PM | #8 |
I would like to put 4 inch spindles in my R30 but nothing exsists.
07-08-2009, 09:18 PM | #9 |
check out this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=345479 |
07-08-2009, 09:51 PM | #10 |
If i got 4 inches of lift in the front could i fit 31/11.50 tires?
07-09-2009, 08:22 AM | #11 | |
My truck with 32"s..
07-09-2009, 11:07 PM | #12 |
My old '79 2wd Blazer had a set of 32/11.5/15 on it. It was stock hight and no rubbing at all.
07-08-2009, 10:42 PM | #13 |
Dually Pride
my stock 2wd 1 ton fits 33, no rub
you can use 1 ton coils, but it'll ride rough as hell ever think of a body lift?
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
07-08-2009, 10:50 PM | #14 |
6.0 powered square
here a 3" body lift with stock worn coils on 32s
with hd coils
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-12-2009, 05:07 PM | #15 |
If you look at my pics I run 33x12.5 with no rubbing, actually it looks 4 wheel drive now. I used 3" Fab tech and ball joint spacer and a 3" body lift. I drive it everyday no problems and isnt really that much of a stiffer ride. I put Kyb lifted shocks though.
03-10-2010, 10:31 PM | #16 |
i have a 87 chevy silverado all stock an got 31x10.50 an got good clearance
