07-09-2009, 09:47 PM | #1 |
Door Switches
Hey guys,
I have been looking for some door switches to turn on courtesy lights in the floor board. I found these (Delco D6030) used on 80's - 90's GM cars. they were $4.20 each from Rock Auto. My 65 has factory holes in the door jambs that look like they were made for these switches. They fit perfectly. They are sort of self adjusting. The bushing is a press fit on the tube. When you close the door for the first time they adjust to the correct position by sliding on that press fit. They work like a champ. 3/8" fine (SAE) nuts fit the threads. Standard push on connectors fit the connection. No modification to the truck required! TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-09-2009, 10:12 PM | #2 |
Hollister, CA.
Re: Door Switches
Sweet man...looks good !
Thought they always went by the hinges, though.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-09-2009, 10:24 PM | #3 |
Re: Door Switches
Yep Chief,
I think you are right but those empty holes sure needed to be filled up with something. Easy to route the wires under the sill plate. My buddy has a t****aTundra and the door switches mount like these... TR
07-09-2009, 11:29 PM | #4 |
Resistance is Futile
Re: Door Switches
Where were you when I was fishing crap thru the kick panel? Killer idea.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
07-09-2009, 11:48 PM | #5 |
60-66 Nut
Re: Door Switches
Good idea. Like you said easier to run the wires that way. BTW that hole is originally for a rubber bumper.
07-10-2009, 09:50 PM | #6 |
Re: Door Switches
Thanks Pro & Cap'n
It didn't occur to me to look at the assembly manual. Bumpers sure enough. Maybe that's why my doors close so easily. They probably cut them off and threw them away when the truck was painted. Oh well, they are switch holes now. TR
