Old 07-09-2009, 11:06 PM   #1
frankyjoet
Unhappy backfiring 350v 5.7l man trans
Hi, went through process of finding tdc. Have timed eng at 8d btdc with vacumm plugged and hose plugged. When i hooked up the vac hose the timing changed TO advance. The eng starts but when i accel the carb backfires. Do i have to take out the dist and find tdc again.
thanks in advance
frankyjoe
frankyjoet is offline   Reply With Quote
Old 07-10-2009, 01:52 AM   #2
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: backfiring 350v 5.7l man trans
Normally if it backfires through the carb the timing is retared.
Turn it counter clockwise and see if that helps before you pull it.
heavychevy79 is offline   Reply With Quote
Old 07-11-2009, 11:45 AM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
When you plug the vac hose in at idle on a stock setup, the timing shouldn't change. If it does, the hose is plugged into the wrong port. You need to find a ported vac source instead of full manifold source.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
