Old 07-10-2009, 10:51 AM   #1
olblue81
olblue81's Avatar
drop spindles and rally wheels
This has probably been covered like a hundred times in the past, so sorry if this is a repeat. I didn't come up with anything by searching.
Just wondering if a 2.5" or 3" drop spindle will fit inside a stock 15" rally wheel.
I'd like to lower my truck some to get it out of the clouds, but I have no future plans of air bags.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 07-10-2009, 11:36 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: drop spindles and rally wheels
2.5" will be fine, but I have heard the 3" might lead to some rubbing issues. I've ran the 2.5" with rallys myself, but not the 3", so hopefully someone else will chime in soon.
Nice truck BTW, I love the color!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-10-2009, 11:55 AM   #3
olblue81
olblue81's Avatar
Thanks!
Stu-
Old 07-10-2009, 12:00 PM   #4
hessian18
Gen III Power
hessian18's Avatar
Killer truck !
From what I have read around with a 3'' spindle you will have to "relief" or "grind" the lower a-arm to clear the rim (at full lock )and possibly take some off the top of the caliper to clear the rim.
I totally dig the truck, My truck is a 81 long bed and I call it ol blue too !!
Im still hunting for a sport bumper to replace my step like yours
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 07-10-2009, 12:11 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
4 inch backspace on the wheel is the issue.
I have used 2.5" and 3" drop spindles,... and if the wheel has a 4" backspace you will need to do some clearancing on the lower control arm around the ball joint area.
It's not a big deal.
Keith
Convert to disc brakes.
Old 07-10-2009, 12:21 PM   #6
hessian18
Gen III Power
hessian18's Avatar
Great information lolife
I may drop mine soon if $$ permits ( and the ole lady ) ahahaha
---Bob---
Old 07-10-2009, 12:51 PM   #7
LiveAnimals
LiveAnimals's Avatar
I'm running DJM 3" drop spindles w/8" rallys all around. I had to smooth out the top of the spindle because it rubbed. All in all they look great and there was very little mod to get them just right. All I used was a angle die grinder and a carbide bit.
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 07-10-2009, 01:30 PM   #8
hessian18
Gen III Power
hessian18's Avatar
Have a picture of you truck liveanimal ??
---Bob---
Old 07-10-2009, 01:38 PM   #9
flamingbig10
6.0 powered square
flamingbig10's Avatar
My wheels have 4 1/4 back spacing with 3" djm spindles and I just had to grind a little off the brake caliper ear
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-10-2009, 03:48 PM   #10
jasonblinn
jasonblinn's Avatar
i just put 3'' drop spindles on my 1986 with rally wheels and had to grind the spindles,not much only about 1/8.wish the company i bought them from wouldve told me they wouldnt work with 15s
jasonblinn is offline   Reply With Quote
Old 07-10-2009, 03:50 PM   #11
evan
evan's Avatar
What brand?
Evan B.
evan is offline   Reply With Quote
Old 07-10-2009, 03:53 PM   #12
jasonblinn
jasonblinn's Avatar
springtech..got them off ebay
Old 07-10-2009, 09:05 PM   #13
olblue81
olblue81's Avatar
Thanks for the input everyone. By the looks of it a 2.5" spindle just clears and a 3" requires some grinding.
Stu-
Old 07-11-2009, 07:22 AM   #14
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
If I used a 2 1/2 inch dropped spindle and 1" lower spring will 15 x 8 rallys rub on my 72?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-11-2009, 08:48 AM   #15
boatpuller
boatpuller's Avatar
my 3 inch drop spindles with a 1 inch coil rubbed pretty bad on stock rallies.thats why i ended up with 17's.i had to grind more than the lip.the area around the bottom ball joint was hitting.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-11-2009, 09:14 AM   #16
moneyeater
moneyeater's Avatar
I cant even tell if i have a 2.5 or 3 inch spindle.They are from belltech.
i had to grind of the lip of the lower a arm.the wheels rubbed at full lock but i haven´t rallies i have eagle 589 s.
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 07-12-2009, 10:41 PM   #17
LiveAnimals
3" DJM Spindles
Western Chassic Flip Kit
8" Rallys 275/60 15 - rear
255/60 15 - front
Kameron
Old 09-07-2009, 08:15 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by moneyeater View Post
I cant even tell if i have a 2.5 or 3 inch spindle.They are from belltech....
Volker
Belltech is 3"
olblue81- If you don't mind doing a little extra work to make them clear, the 3" spindle is the way to go. It's much better to have spindle drop where you can rather than spring drop. The spindle will on effect the ride, whereas the shorter the spring the stiffer it becomes.
Besides, you will want more later....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-07-2009, 08:50 PM   #19
silvereagle07
silvereagle07's Avatar
Originally Posted by N2TRUX View Post
Belltech is 3"
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 07-12-2009, 11:04 PM   #20
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I have 3" spindles, and 2.5" springs. Running the stock rally wheels with 245/60/15 tires. And I had some rubbing on the spindle but it only needs to be knocked down a tiny bit. I worried about it at first but...have no fear, if 3" is the drop you want, grind the spindles to clear the wheels. You will be fine. Here is a couple I took today next to a wheat field. Hope this helps you decision.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-07-2009, 06:21 PM   #21
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
more input on your tire and wheel combo please?????
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 09-07-2009, 11:38 PM   #22
Driveway Dreams
I have car A.D.D.
Did you want more info on my set up? If that's what you wanted, here you go. It is a stock set of wheels. I have 245/60/15 Cooper Cobra tires.
-Gerald
Old 09-08-2009, 12:32 AM   #23
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
sorry about that man, what drop do you have? are those 15x8 all the way around??
Old 09-08-2009, 09:29 AM   #24
nlped
nlped's Avatar
I used a 2.5" McGaughy's spindle and a 1" drop Belltech coil spring that I actually cut a 1/2 a coil off of to set the front down where I wanted it. It is just a flip in the rear. I am running 15x8 Rally's w/ 255/70r15's all the way around with absolutely no rubbing. Oh, BTW, it rides great!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-23-2009, 11:34 AM   #25
quadracer812
quadracer812's Avatar
anybody have any clearing issues with a 7 inch rim on 3 inch spindles?
quadracer812 is offline   Reply With Quote
