Old 07-13-2009, 02:31 PM   #1
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Front Air Bags on a 66
Hey guys new to site and i want to bag the front and need some ideas and some pics-the rear is all ready bagged . thanks
GGinferno is offline   Reply With Quote
Old 07-13-2009, 05:33 PM   #2
justbad
Re: Front Air Bags on a 66
If your rear has airbags then you should know the drill .The front while a lil more involved are as simple as a spring change,the adapter plates are avalible all over the place. My only segestion is to run good shocks ,a set from a 63-82 vette will work insted of a drop shock and you will have a greater selection.you should also replace your ball joints and any other high wear items while your front end is apart Ive seen ball joints and complete tie rod end sets for as low a 90 bucks and a set of kyb gas adjust are about 40 bucks apiece.you will thank me latter.
justbad is offline   Reply With Quote
Old 07-13-2009, 06:42 PM   #3
Dinos63
chevy only
Dinos63's Avatar
This trucks badd
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-13-2009, 11:18 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Are you looking for something simple and budget oriented? The most economical route is a set of upper plates and lower bag cups. The upper plates bolt on to your factory crossmember, and the lower cups bolt to the bottom of the bag, and then set in the lower control arm's spring pocket. If you're looking for the more expensive route, you can purchase some cnew control arms that are set-up for an air bag.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-15-2009, 04:25 PM   #5
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is a 2.5 drop spindle with Slam Specialties Bags with a 3 inch cup.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-15-2009, 09:32 PM   #6
xratt
xratt's Avatar
I bought my 66 bagged. But im redoing the whole set up. im tearing it apart right now. I pulled the motor out today and it goes to the machine shop tomarrow. Then i start tearing apart the front end. I bought new lower arms made for bags, and new bags from airbagit.com. But like a slacker, i forgot to take any pics today. i will take a few as the project progresses.
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 07-16-2009, 05:21 AM   #7
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
awesome truck it is nice to see a long bed layed out!!!!!
gostranger is offline   Reply With Quote
Old 07-17-2009, 01:01 AM   #8
GGinferno
GGinferno's Avatar
Thanks for the info guys and pics guys..just wanted to see the front set up.
Old 07-19-2009, 03:47 PM   #9
kevenahus
The air bag system you guys are using is it on the original chassis? What are some good web sites to purchase airbag systems?
kevenahus is offline   Reply With Quote
Old 07-19-2009, 06:39 PM   #10
protrash64
Resistance is Futile
protrash64's Avatar
You may want to look around, there are vendors on this site, but I used Suicide Doors for the brackets and bags.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-19-2009, 08:57 PM   #11
kevenahus
So how much did your air system run you? I looked at ridetech.com and their full system runs about $5,300. I’m not sure I want to spend that much. If they all run that much I might go with the air shocks all around. What ya think about air shocks?
Old 07-19-2009, 11:17 PM   #12
protrash64
protrash64's Avatar
GG....you can cut at least a 1/2'' off that lower cup before installing it. I did with no issues and gets a little lower in the front. Skip it if you need hite...your truck is lookin' low to begin with.
Old 07-19-2009, 11:54 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
There are lots of other ways to go that are much less money! Shoot me a PM and I will help you figure out the best route to take with your budget!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-20-2009, 12:09 AM   #14
xratt
xratt's Avatar
i'm going though airbagit.com for the supplies to rebuild my front end. I should have my shipment in tomarrow. I will post a comment on the quality of the goods. New lower control arms (complete), new 2600 air bags, new 4 way air valve system, and a 1 way air check valve, with shipping ran me $1002.00. I've been on the phone and email them several times now and have great responces.
1955 VW Buggy, 2.0L
1978 Honda CB550
Old 07-20-2009, 03:08 PM   #15
kevenahus
Hey Im old school what does PM mean?
Old 07-20-2009, 03:15 PM   #16
kevenahus
Sorry bro, but what does pm stand for?
Old 07-19-2009, 03:58 PM   #17
jonathan-m
GG, not to thread jack here.. but do you have any other pics of your truck? that paint job looks sweet.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 07-20-2009, 06:04 PM   #18
Dustin07
Stirrer of the Pot
what would arms do? What type of bags do you have and what is their min and max size when aired out and fully inflated? Are they bags fully compressed when laid out? that may be where you are losing lift. I think Slam 7's have like 7-8" of lift which should be more than enough for anything to get off the ground safely.
Dustin07 is offline   Reply With Quote
Old 12-21-2009, 09:22 PM   #19
threeonthetree
threeonthetree's Avatar
sweet truck!
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 12-22-2009, 10:05 AM   #20
xratt
xratt's Avatar
Yeah what ever happened with this truck? Mines finally on the road. Low as hell. Hit my tubular lower a-arms on every thing. But I love how low it sits. Love my 2600 bags in the front. Now I want some more for the back. But it will have to wait.
1955 VW Buggy, 2.0L
1978 Honda CB550
