Old 01-06-2003, 09:03 PM   #1
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
Question Motor mounts
Has anyone used late model style motor mounts, in there trucks,
I sat the 454 in my truck to break it in, (and of course I couldn't leave it on the stand any longer without hearing it) and I used some late model mounts, other than one hole not lining up, what would be the problem with using them verses the original style,
that would appear to raise the engine up, and also doesn't look as strong...what have you guys used, my set up is a '68 swb, with a 454, and a turbo 400. Are there going to be any unforseen problems Thanks John
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 01-06-2003, 09:14 PM   #2
67cst
i love summertime
67cst's Avatar
howdy, bout your question, im using an 85 frame, but the engine mounts are off a van, ill try and get pics next weekend, it was snug goin on, those rubbers are a *****...but we got it and its lookin damn sweet....
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-06-2003, 10:13 PM   #3
crazy longhorn
Fabricate till you "puke"
The later clamshell style mounts should be a better deal than the old style mounts as far as strenght....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-06-2003, 11:15 PM   #4
racedvl
racedvl's Avatar
I have been toying with the idea of using 73 and up engine towers, and the clam shell style mounts. Might try it when I start my engine swap soon.
racedvl is offline   Reply With Quote
Old 01-07-2003, 12:21 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If it'll bolt up and you can shut the hood...go for it.
Like mentioned, they are better mounts.
Old 01-07-2003, 02:46 AM   #6
67_SS396
I used a set of '74 mounts in my '67 and BB. They took some massaging, but they went in fine. I run a 3" filter and 1" carb spacer with just enough clearance with the hood.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
