Grandpa in the rustmobile...
can you tell the gear ratio by the number of teeth on the ring gear?
Ring Gear has 43 teeth on it
the axle where it goes into the differeiantl has 16 and some other place the guy counted 10 teeth im trying to figure out the ratio, if this info doesnt do anything let me know i'll get more info lol sorry for the WTF numbers lol......
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Junior Member
Re: can you tell the gear ratio by the number of teeth on the ring gear?
I think my son told me once that there are numbers stamped on the chunk that you can see when you take the cover off.
I am sure some one else will chime in. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
if the ring gear has 43 and the pinion is 16 then - 43 divided by 16 = 2.69, and 43 divided by 10 = 4.3. i have to admit that these are some odd numbers. the ring gear is the big one that is ring shaped, and the small one (pinion) is the small one that is attached to the driveshaft yoke. not trying to talk down, just trying to be very clear. i think u need a recount
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project Last edited by lofly'a; 07-15-2009 at 08:06 PM. |
i'm not trying to sound like a jack a$$, but didn't you have a thread on finding your ratio a while back where you were told to either look at the numbers on the gear or just spin the drive shaft 1 full turn and see how many times the tire turns. You are making this way to hard.
if you can see the teeth then you can find the ratio stamped ON the ring gear WITHOUT counting
yes i did for MY rearend i converted to 5 lug disc on the front and have been hunting a rearend, i found one about 1 hr away but id rather find out the ratio without spending 20 bucks in gas getting there, the guy didnt know the ratio but he said there was 43 splines on the big gear (ring gear) im not very smart when it comes to these trucks so i ask you guys, if the numbers dont add up i'll understand i may have to just drive up there and do it myself....
![]() Join Date: Jul 2004
Heres a quick cut and paste from a site I found with truck 12 bolt gears, don't see any 43 tooth sets here.
GM12-308 3.08 40-13 GM12-342 3.42 41-12 GM12-373 3.73 41-11 GM12-373X* 3.73 41-11 GM12-433 4.33 39-9 GM12-411X* 4.11 37-9 GM12-456 4.56 41-9
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-15-2009 at 09:59 PM. |
I doubt that he was able to count the pinion teeth without removing everything.. as stated though have him looke for a little stamped number on the outer edge of the ring gear. it should say something like 41:11 (41 divided by 11 = 3.72727R) or 3.73 gears.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
