??? about drop...
OK, I have 2" drop springs in the front and a 2" block in the rear. If I add 2" spings to the rear, will the truck be level?
Re: ??? about drop...
Don't know if this will help. But from the factory on a c10 there is 2" difference from front to back I believe. Hope this helps.
Grandpa in the rustmobile...
prin the rear of your truck needs to drop 2" befofre its level, so yes your correct.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
C10 Club Tennessee
yes, you need to go two inches lower in the rear
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
31" from highest point in front fender well to ground and 34" in rear fender to ground was stock according to the LMC catalog. Take your measurements and see if it'll work for you...
"Some people spend an entire life time wondering if they ever made a difference... The Marines don't have that problem." President Ronald Reagan '68 C10 SWB 396/350/4.11 ![]() |
#6 | |
WTB this ad
I don't doubt that LMC prints that kind of info...but those measurements are useless unless the vehicles being compared have the same size tires/wheels with identical air pressure. |
Sounds like an SAT math question. You need to measure front and rear ride height and determine for yourself as every truck can be slightly different from factory specs, especially after all these years.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Exactly. You need to judge for yourself what your truck needs. They are all a little different. Just park it somewhere and walk a ways away from it and stare at it awhile to decide for yourself.
FYI:
I have a 68 Longbed/Fleetside (Added weight I suppose on rear) with a 250 Inline 6 (Lighter than 350?) I purchased 2" Drop Spindles for the front and replaced the original springs with factory stock size. Out rear with coils I purchased/installed 4" Drop Springs with shorter shocks. Without a tailgate and load I set about 1/2" to 3/4" high in the rear. Hope this makes sense Last edited by SpeedTriple; 07-16-2009 at 05:45 PM. |
A 2/4 drop looks good. It may not be exactly level, but it's close.
I recommend getting 4" springs and doing away with the blocks altogether. If you ever decide to do something else later, 2" drop springs are hard to get rid of.
#11 | |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I agree with 68Stepbed also, but for different reasons. I would have installed 4" rear springs first, then you would have the option to bring the rear down more with the blocks and it would be a little more accurate. Keep in mind that you will probably need to install at the verry least an adjustible pan hard bar too, to recenter your rear end. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() I did a dick move to the ole girl. I heated the fronts and put a 2inch block in the rear and then heated teh rear a tab. I only done this to see how I wanted the truck to sit. Well, I have recently installed 2inch fronts and the back in not what I like. Also, the back rides like crap. So, I am redoing everything the CORRECT way! Thanks everybody!!!! |
