Old 07-20-2009, 10:04 AM   #1
69_C10
Doing it my damn self.....
69_C10's Avatar
Frame Cleaning Solution found!!!!
Greetings Gearhead Collegues...
While tearing down my baby I was dreading the ineviatble frame cleaning and detailing. I read a couple of threads about oven cleaner from the dollar store. I was in extreme doubt about using this on my frame and the power it would have aginst 40 years worth of grease oil, grime, salt, etc, etc.
This stuff works wonders!!! I had a very thick build up of "funk" all over the frame from leaks from everywhere literally. I caoted the entire frame with the oven cleaner..(3 cans) and let it sit and work for 1 1/2 hours. I fired up my pressure washer and actually sprayed the frame clean!!! I was in awe at the power of the oven cleaner. Now I'm down to business on blasting my frame and finishing it off by primer and paint.
All of that cost me $3.00 and a little water. I figure some guys projects might be at the same status as mine and looking for a cheap frame cleaning solution and wanted to pass along for what it's worth.
Keep the projects going..
Mark...
Project 69 Stepside...http://67-72chevytrucks.com/vboard/s...d.php?t=290761
69 C10 Stepper - Current Build
94 Silverado - Driver
05 Hummer H2 - Unique Whip
69_C10 is offline   Reply With Quote
Old 07-20-2009, 10:14 AM   #2
kev2809
low n' slo
kev2809's Avatar
Re: Frame Cleaning Solution found!!!!
nice, you take any pics by any chance?
kev2809 is offline   Reply With Quote
Old 07-20-2009, 11:16 AM   #3
au03z71
au03z71's Avatar
Sounds like a winner! Any particular brand of oven cleaner?
au03z71 is offline   Reply With Quote
Old 07-20-2009, 11:22 AM   #4
Shane
Shane's Avatar
the cheaper the brand the better ... Dollar General store brand works awesome ... be sure to wear gloves and eye protection
Shane is offline   Reply With Quote
Old 07-20-2009, 11:58 AM   #5
SCOTI
SCOTI's Avatar
Originally Posted by Shane View Post
.....be sure to wear gloves and eye protection
Definitely true words of wisdom. Outside breeze will easily carry this stuff. If it gets in your eyes or on your skin, you'll be very uncomfortable for several minutes @ the minimum.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-20-2009, 12:15 PM   #6
au03z71
au03z71's Avatar
That's a fact. It's not too easy on paint jobs either.
Old 07-20-2009, 08:36 PM   #7
69_C10
69_C10's Avatar
Hi Gents,
I took a couple of after pics when I used the oven cleaner. I didn't have the forethought to take any before pics but, believe me, it was absolutely funkified with grease, grime, and nastiness. The oven cleaner is from the Dollar Store and is nothing short of amazing. 1 application did the trick (3 cans) did the entire frame. Followed by a pressure washer and presto, ready to blast, prime and paint.
Thanks,
Mark Ingle
Asheville, NC
Mark...
Old 07-22-2009, 01:10 PM   #8
originalJD
James
originalJD's Avatar
Yes, this stuff works wonders. I recently used it on my latest project thinking it could never work and it did better that anything else I've tried. And gloves are an absolute MUST to use. My finger tips especially around my nails were soooo chemical burnt it was rediculous. I always have to learn the hard way it seems.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 07-22-2009, 07:58 PM   #9
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Also works great for de-greasing motors.
Does a kick azz job on a dirty BBQ grille too!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 07-22-2009, 08:17 PM   #10
Shane
Shane's Avatar
Never had it to be harmful to aluminum ... the anodizing on the other hand will be removed.
Old 07-22-2009, 11:22 PM   #11
Skirkpat
Skirkpat's Avatar
I would suggest at the very least a dust mask, but next time I am getting out the paint respirator...I got a good lungfull the other day,it's not alot of fun. But I did get the engine bay clean"er"
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-22-2009, 11:36 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
There's also Simple Green... it works!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-28-2009, 11:52 AM   #13
highschoolbuilder
Does. It workfor. Rust?
highschoolbuilder is offline   Reply With Quote
Old 07-28-2009, 09:02 PM   #14
69_C10
69_C10's Avatar
It left the rough rusty spots but, you'll be impressed with it.
Mark...
Old 07-29-2009, 01:07 AM   #15
highschoolbuilder
I have a good amount of surface rust. Any tips?
Old 08-01-2009, 12:10 AM   #16
my67chevytruck
Under Construction
my67chevytruck's Avatar
sand, and then paint with por-15
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-01-2009, 05:21 PM   #17
highschoolbuilder
as in sand it? or sand blast it?
Old 08-01-2009, 08:53 PM   #18
POPO1984
POPO1984's Avatar
Sand Blast would be the best
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 08-02-2009, 11:55 PM   #19
highschoolbuilder
okay any thread you can direct me to that would help on the art of sand blasting? haha
Old 08-03-2009, 07:15 AM   #20
au03z71
au03z71's Avatar
I'd do a search for one. It seems like somebody posts one up in the paint and body section on a monthly basis. Also, there is a nozzle that you can put on a pressure washer that basically acts as a jet-pump and you can use it to sand-blast just about anything. The only down-side to it is wasted sand...but sand is relatively cheap.
Old 08-04-2009, 10:04 AM   #21
69_C10
69_C10's Avatar
Hi highschoolbuilder, I was going to buy a sandblaster and learn this myself but, when I looked into te cost of the blaster, sand, and making a huge mess to clean up afterward. I called some shops and found that they would actually blast and prime the frame for a third of what I would spend doing myself. No brainer right??
Food for thought....good luck on your project.
Mark...
Old 08-04-2009, 01:46 PM   #22
highschoolbuilder
what type of shop should i look for and what price should i look to spend?
Old 08-04-2009, 03:34 PM   #23
69_C10
69_C10's Avatar
Just to give you an idea, to blast my frame he was going to charge between $150 and $200. That was the best deal I found. Most shops was going to charge between $80 and $90 per hour. I like the flat rate better, no surprises at time to pay you know.
Mark...
Old 08-04-2009, 03:44 PM   #24
highschoolbuilder
okay. sounds good. can they just paint it with a black gloss after the prime. and if so will it be that much more expensive? and can they do just the back of the frame. i know it sounds weird but im doing a daily driver build and i took off the bed to replace the bed and im just doing that part right now.
Old 08-22-2009, 02:14 PM   #25
oldcarfart
I scratch thru the crap with a screwdriver, etc. then soak with oven cleaner. This lets the cleaner get behind the crud and lift it rather than hoping it soaks all the way thru.
oldcarfart is offline   Reply With Quote
