2.5" Drop Spindle Step-By-Step (as completed at the TN Meet & Greet last weekend)
Hi all!
We just got back from the Tennessee Meet & Greet at Ron's (click here for pics) this last weekend. I took lots of pictures of the group project, and I need to post the Step-By-Step of what we did. We took a 1968 Stepside (it belongs to thelonerife, not me) and we added 2.5" drop spindles, and cut coil springs (for an extra 2.5 inches). What fun! FYI, I have been known in the past for my elaborate project descriptions including lots of photos. It will take me a while to finish this thread (at ten pics per post), but I promise to complete it! Here are the details: First, put the truck up on jack stands with a jack, and remove the wheels. Boy, if you don't know this step, I suggest you just read this thread, and leave the work to the mechanics! ![]() Make sure to bury yourself pretty deep into the wheel wells of the truck, or you will never enjoy this project. Here is thelonerife (Chuck) buried in a wheel well. And here is 5150 (Brian) also buried inside a wheel well. It is also important to have very important supervisors. Here, pickles (Margaret) is making sure everything is correct. And here are some other very important supervisors. On the right is our TN resident teacher, woodridge (Woody), who is always the best technical support line you can find! He made sure not to bring a forklift license this year! :LOL: Now, it is extremely important that you have lots of extra chairs around for all of us who want to watch. ![]() From left to right, this is retodd7711 (Todd), luv2xclr8 (Craig), tycoon4u, and blue_71 (Josh). OK - Back to the Step-By-Step: Remove the connection to the tie-rod, so the steering is disconnected. Next, turn one of the wheels/spindles/brake assemblies so you can easily get in behind it. You need to remove a cotterpin from both the top and bottom castlenuts on the ball joints. Blue_71 (Josh) has just informed me that you must have a jack under the lower A-arm with upward pressure before you can remove these castlenuts. Yes, I will continue posting below.... keep reading! ------------> Last edited by N2TRUX; 03-25-2011 at 09:44 PM. Reason: Fixed Picture Links |
Re: 2.5" Drop Spindle Step-By-Step (as completed at the TN Meet & Greet last weekend)
AFTER (and only after) the cotterpins are removed, the castlenuts can be removed from the top and bottom ball joints.
Next, use a PICKLE FORK between the spindle and the ball joint to loosen the spindle from the joint. You have to do this on top and bottom. This is a PICKLE FORK: It will take quite a bit of hammering. Go 5150 (Brian)! After the ball joints are loose, the wheel/spindle/brake assembly should just lift right out. Chuck decided to replace his ball joints while the spindles were out. To do this, you must remove the factory rivets that hold the factory ball joints in place. THIS IS NO EASY TASK!!! But I will show how to do it here. If you do not want to replace your ball joints, you can skip down to the steps below where the upper A-arm has been reinstalled. To replace the upper ball joint, the upper A-arm can be removed from the truck. If you lift up on the A-arm, there are two bolts underneath that can be removed. Be careful - there are also SHIMS that align your suspension correctly. Keep track of the shims, as to which bolt they came off of. Make sure to put them back when you reinstall the A-arm. More to come below -------------------> Last edited by jewels.; 07-22-2009 at 11:59 AM. Reason: Fix Picture Links |
There are several methods to getting the rivets out of the factory ball joint. My advice is to skip to the last one here, because it was successful.
This first method did not work: You can grind down the rivets on the top of the A-arm. Then, after the rivets are ground down, you can try to use a punch to hammer out the rivets. THAT METHOD DID NOT WORK. Blue_71 (who is a Chevy Dealership Master-Certified ASE Mechanic) says that this method hardly ever works. Blue_71 says that he has been successful removing factory ball joint rivets in two ways. First, you can drill out the rivets to loosen their hold. However, this takes a mean drill bit, and a very large, industrial drill. Second, he recommends to use a chisel (or even a pickle fork) to hammer between the rivet plate and the A-arm. It will take a LOT of hammering, and a LOT of patience, but the rivets will soon give way. This is Blue_71 (Josh) hammering away, and Chuck looking on. This is what he used on Chuck's truck at the meet. Again, this is not for the faint of heart. It takes a LOT OF HAMMERING! Once the rivet plate has been removed, the rivets will come out of the A-arm easily with a hammer. Gotta take a break and help Josh move a car right now. But I'll be back in a few hours to post some more pics. Still more to come ------------------------> Last edited by jewels.; 07-22-2009 at 11:50 AM. Reason: Fixed Picture Links |
chrome makes it go FASTER!
Still seeing some red x instead of photos.
Good write up jewels!
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#5 | |
If you paste the HTML link into another tab or webpage, and then you go back and refresh this thread's page, the picture appears. Perhaps it is too many photos for the thread to load at the same time? Does anyone have any suggestions for this problem? I teach web page design and development classes, and I'm pretty convinced this is an interpretation problem, not an availability of pictures problem. ![]() ~jewels.
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
Tot Roddin'
jewels, I will see if I can get you some help on the picture issue. Hang tight!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Tot Roddin'
Seeing half the pics and half red x's ...
From what I can tell though, this is FAQ worthy!
Restoring a 68 SWB
Very nice writeup!
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
I am a Referee of life.
Nice job on the writing Jewels.I get some red X's also but have done this and seen it done.The ball joint press shown in the pics will not work.The c section clamp is too short.In the pic of it on the spindle everything is right but the round tube that is with the Ball joint press does not have room to be put on top of the round stepped plate under the ball joint.I learned this the hard way and wound up cutting some spacers from tubing to make it work.The problem is that 67-72 ball joints are taller than most others.
Again great write up and story.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jul 2007
I cut the dust shields down and put them on.Also I changed the center caps.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
86 C10
Nice write up, good job, looks great!!!
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
Velocity Speed Shop
Great job. I am getting ready to do the same thing. Thanks for the help.
--------------------------------------------------- My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143 My Garage ..... http://www.hubgarage.com/mygarage/OCD69 |
Restoring a 68 SWB
The rivets in mine weren't that hard. Just did them last night. I cut x's in the heads and then chiseled the head off. Then took an air hammer and tried to punch them out. A couple of them came out and then I had to pry the upper ball joint away from the arm. After that I hit them a few more times with the air hammer and they came out. FYI
![]() Join Date: Oct 2010
why we cant see the pictures on the project anymore??
#15 |
Happy to be here
![]() Join Date: Mar 2000
Unfortunately the image host that was used no longer exists.
#16 |
real suck
I was going to check those pictures and do my truck i have the same project so sad |
#17 |
too bad the pics aren't in the thread...
![]() ![]() It ain't yours, if you didn't build it! |
#18 |
Grandpa in the rustmobile...
maybe thelonerlife has them saved?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#19 |
This would have been great in the FAQ section.
#20 |
Happy to be here
True, but it still would not have any pics. Thats why we recommend using the sites photo gallery to host your pics. If you upload them here, there will always be available for viewing.
#21 |
I try to click on the red X ,,,,copy anbd paste on proprtties and nothing
shame the pics are gone try to email jew but his mail box is full |
#22 |
Ok, so it took a little longer than we had hoped to move that car, but I promised to complete this post, so I'm getting back to it now.
To continue: We've removed the upper ball joint. Now we need to remove the lower ball joint. Usually, you can use a ball joint press to do this. However, no matter who tried it, the press kept coming apart. No one could figure out how to use it. So, we just ended up using BRUTE FORCE! ![]() (Hmmm, I don't seem to have a picture of Brian swinging that sledge hammer with all of that force. I guess I was too wrapped up in watching it. ![]() Once the lower and upper ball joints are removed, it is really easy to install the new ones. They do not use rivets when you put them in. Instead, they just use bolts and nuts. So, just assemble the new ball joint back in place. And don't forget to add the grease zert that comes in the package. Now it is time to put the upper A-arm back in place. First, put those shims back in the same location as they were before. More to come -----------------------> |
#23 |
Start the nuts on each stud, but be careful to keep the shims on there. Hold your upper A-arm up and out of the way. Then tighten it all down. We need to put the lower ball joint back in place. Unlike the upper ball joint, the lower ball joint needs to be pressed into the lower A-arm. However, that pesky ball joint press has not been working out for anyone this weekend, so we had to resort to some creativity. Per Woody's (woodridge's) directions, the jack was placed under the lower ball joint. A slight amount of gentle pressure was applied to the ball joint with the floor jack by using a few of the pieces out of the ball joint press kit. Then, a sledge hammer was use very carefully to hit on the A-arm on each side of the ball joint. DO NOT HIT THE BALL JOINT! You don't want to ruin the ball joint. The pressure from the jack will carefully push/press the ball joint up into position. |
#24 |
Now it is time for the spindles to go back on. Before we get to that, lets talk about what a drop spindle does. Here is a comparison of a regular spindle and a drop spindle, side-by-side. Notice where the center circle is on each one. The center circle is where the wheel is attached (the spindle).
Notice on the shiny new spindle, that the circle is about 2.5inches away from the old spindle, thus lowering the wheel 2.5 inches from where it used to be. (Thank you to Blue_71, Josh, for this great description and explanation. He is holding the spindles for me in these photos.) It is a little more difficult to see, but here is a view from the outside of the spindle. Now that we have both ball joints installed, we need to put the spindle on. There are many different ways to do this, but here is what the group did. First, slide the spindle onto the upper ball joint. Then, add a castlenut to hold it in place. Line up the bottom of the spindle with the bottom ball joint. Because the group did some work on the stock springs in Chuck's truck, the spring is pushing down on the lower A-arm, and the lower ball joint will not reach thru the spindle (the lower castlenut cannot be started). In this case, place a jack under the lower A-arm, and lift up with the jack. (You may want to use something to protect the ball joint from damage.) This will hold the A-arm up enough to start your castlenut on the lower ball joint threads. Then, tighten down both castlenuts. For some reason, on Chuck's truck, the dust covers on his new spindles kept hitting the lower A-arm and causing an interference. I guess sometimes aftermarket parts don't perfectly fit our trucks. Bummer. So, Chuck decided to remove the dust covers. He is going to make a small modification to them and put them back on the truck later. Well, there it is. The new spindle with it's drop all in position. Nice and perty. What do you think? Of course, there is still a truck with no brakes, wheels or steering. So, we still have a little work left to do. Let's keep going. --------------------> |
#25 |
Next, we need to assemble the tie rod back in place (so we can steer this thing down the road).
And don't forget to add cotterpins to the castlenut on the tie rod, and onto the spindle as well (top and bottom). Now lets talk about the brakes. How do you take the brakes off the old spindle/wheel/brake assembly and move them to the new one? Here is the old spindle/wheel/brake assembly: First, you need to remove the dust cap. Just use a little hammer and a small screwdriver. Don't hit hard, just pry gently and it should pop right off. Then remove another cotterpin from (yet another) castlenut. Then, take the castlenut off. Now be careful, because the wheel bearing and all of its greasy parts (washers, ball bearings, etc.) are all in the center of this rotor. BTW, the grease on Chuck's truck is red in these pictures. PERTY! ![]() More to come ----------------------------------> Last edited by jewels.; 07-22-2009 at 01:31 PM. |
